iDash EGT settings
Old May 2, 2023 | 12:29 PM
acdii's Avatar
acdii
iDash EGT settings
Right now I have it setup like this
Not going to touch the right side, but which EGT probes should I monitor for towing? I have 1 & 3 now.
Old May 2, 2023 | 04:51 PM
chadstickpoindexter's Avatar
chadstickpoindexter
I watch 1 and 4 on my main screen, along with the regen status (just in case I forget to turn it back off or something...) I always wait for EGT1 to get back down to at least 400F before shutting the truck off. Here is my main screen:
And if I am actually in a regen, here is the screen I monitor for it.
Old May 3, 2023 | 07:40 AM
acdii's Avatar
acdii
Geez how many EGT probes are there?
Old May 3, 2023 | 08:25 AM
Overkill2's Avatar
Overkill2
x2 on EGT1 and EGT4... I monitor for daily driving.
There are 4 EGT sensors in the exhaust but there are also two EGT sensors for the EGR I believe...
I have a Regen screen set up that I watch during active regens..
Old May 3, 2023 | 08:44 PM
senix's Avatar
senix
EGT 1/1 and 1/4. there are four that the idash can pickup.
1/1 is near the turbo and 1/4 is after the DPF..
those are the ones that count.
Old May 4, 2023 | 10:36 AM
acdii's Avatar
acdii
I set my left bank up with 1/1-4 and wi run with that a little and probably do the 1/1 and 1/4. It looks like they are close to 1/2 and 1/3 in temps. Will know more once I start towing.
Old May 9, 2023 | 08:54 PM
jimzpsd's Avatar
jimzpsd
On your bottom right screen.....DPF SL, is that telling you the soot is 49% full or 49% cleaned. Sorry if its a dumb question. I did a small 150 mile road trip today, and mine read 30% when I started and upon arriving home its at 45%. And also the REGEN screen says off on mine.......will is say ON when a regen begins?
Old May 10, 2023 | 05:52 AM
Overkill2's Avatar
Overkill2
Not a dumb question...
It means truck is reading 49% full for soot load.
When the truck goes into an active regen, the status will go to ACT and ON, flashing between the two, if you have the most recent update 1.24 or close to it.
Old May 10, 2023 | 07:35 AM
jimzpsd's Avatar
jimzpsd
Tank you sir, it does have the latest version (1.24). I will be towing heavy Sunday morning for six hours, so I look forward to watching a regen. in progress. I'm the original owner of the truck and have added DEF fluid many times, but I never witnessed/noticed a regen occurring lol.
Old May 10, 2023 | 10:12 AM
senix's Avatar
senix
Hopefully you have EGT's in the 800's and therefore only passive regens.
Old May 10, 2023 | 11:17 AM
Overkill2's Avatar
Overkill2
You're welcome and you will now...
What Scott said...^^^^^^^^^^^^^
Old May 10, 2023 | 01:57 PM
jimzpsd's Avatar
jimzpsd
Interesting...care to elaborate? I ask because on my old '97 7.3 would read an occasional 1250* F on long hills, egt sensor was mounted just outside the turbo exhaust outlet, not the manifold. I realize these are two different engines.
Old May 10, 2023 | 03:15 PM
senix's Avatar
senix
When I say EGT's above 800 I am referring to EGT1/4, after the DPF. Heavy towing needs to be in that area and above to burn more soot than you are producing.
Old May 10, 2023 | 05:17 PM
jimzpsd's Avatar
jimzpsd
Gotcha, thanks
Old May 11, 2023 | 03:28 PM
Painted Horse's Avatar
Painted Horse
Anything above 572° will do a passive regen. As Senix says, Something around 800° and your passive regen is consuming more soot than the truck is producing.
Hence I can haul tow my horses cross state and have a lower % in my filter than when I started and did not do an active regen. Just the extra heat of towing is burning off the soot trapped in the DPF.
During an active regen you will see 1100° plus temps as the engine pump extra fuel into the exhaust system
