I am hearing Ford has made some changes to address the 'Death Wobble' issue. Supposedly the track bar is longer and at less of an angle. Joints stronger too. Can anyone verify?
A lot of the added weight in the heavier front end components on newer Ford trucks was because of the lighter alloy aluminum body materials used in the rest of the vehicles .. this causes premature wear on components that were not having issues on older trucks, such as steering knuckles, front wheel steering arms, ball joints, stabilizer rod connections etc The only thing to prevent this wear is a monthly maintenance routine that becomes harrowing at times... but it cannot be ignored ... or the cost to repair/replace, becomes tremendous. Not sure, why the reply before mine is relevant ... Because Santa drives a Ford....
Most of it is just getting under there and greasing and inspecting components. Sometimes jacking the front end off the ground and starting the engine to check steering visually .. one of the best fixes for this newer Ford truck issue is to Pop a set of these in, you can do it in your driveway in an hour by yourself, and no need to get an alignment afterwards. Should notice a significant difference. https://www.spcalignment.com/index.p...tion&pid=23268
"These sleeves have a fixed positive camber and caster change and are designed specifically to align trucks that have been lifted or to provide more caster change than our standard 23220 Series sleeves. For maximum drivability and to compensate for road crown, use a 23268 on the driver's side and a 23269 on the passenger's side."
Front Adjustment range: 23268 Cam +.50 / Cas +2.3 23269 Cam +.30 / Cas +2.6
As much as I heard about DW before I got my truck, I was pretty much expecting it the day after I drove it home. Turns out, I haven't really seen many complaints about it here in the 17+ pages since I've joined. Most of the talk I have seen is about what to do ahead of time to prevent it. Maybe it hasn't really been an issue the last few years? Although, I did upgrade my front steering stabilizer around 10k miles and I also grease my front u joints every 5k miles when I rotate my tires.
So the lighter aluminum body causes more wear on the suspension and greasing the two grease fittings on the front axles U joints will prolong the life of the whole front suspension?
I have not seen every part yet, but when I have ordered ball joints, tie rods, and drag link since the 2023 model year was released they are still the same parts listed for previous generation D60 coil front end SuperDutys. Not much has changed since 2005 when this front end was introduced.
Ive still got two 2006 model year parts trucks out back I pull front end components from for repairs on newer generation trucks.
CJC offroad did a Carli lift on their 2023 using the existing '17-'22 lift parts.
The only parts that did not fit are the radius arms. The mounting position on the axle has changed. That tells me me that the suspension is nearly the same. That's not to say that there couldn't be some geometry changes that help mitigate DW.
Chad,
I applaud you for properly maintaining you truck!
How does greasing two zerk fittings on the front universal joints prevent the dreaded death wobble?
I wasn't saying that greasing my u joints does anything to prevent DW, but more of a response to the comment above my original comment. And to be clear, I also wasn't saying that the upgraded steering stabilizer is preventing it either. But stabilizers usually tend to get brought up in threads discussing DW.
Maybe I'm wrong, but I just haven't really seen any reports of DW, at least around here. Sure, I haven't read all the threads, but it seems to me like the earlier models may have had more issues with DW than the newer models do... Sure, there are lots of YT videos about DW, but it seems to be talked about more than actually happening. Kind of like the CP4's on the diesels.
Ill be honest here, I had not even been aware of death wobble myself until 2012 when one of my customers purchased a modified Jeep and consulted with me on what was going on in the front end. Mind you ive been operating a fleet of solid axle front end trucks since 2003 and servicing local fleets since 2006. I have not had any one of my customers work trucks, nor my own ever exhibit the death wobble ive seen in videos and such. Factory geometry achieved with and maintained by factory spec parts and no issues.
I just wondered what you were thinking. I believe your observation is correct, most owners will never experience it.
dw isnt just talk. its a thing. one member chronicled all or most of the threads at that time (perhaps 2yr ago ?) and there was something like 68 threads.
the reason you dont hear much of it today could be for several reason. was it 2yr ago the trucks were lowered which may of helped. theres been 3 or so steering damper revisions which may of helped. front end parts suppliers may have changed which could of helped
