Heater fuse blows??
Old Nov 17, 2003 | 05:10 PM
lotty1525's Avatar
lotty1525
Heater fuse blows??
My heater just all of a sudden blew a fuse and continues to make a spark behind the speed lever. Does it mean my blower is bad? The switch might need to be replaced? Any help would be appreciated.
Old Nov 17, 2003 | 07:15 PM
wezol5484's Avatar
wezol5484
mine did the same thing not too long ago. yea the blower motor switch (speed switch) is most likely fried and also check the relay. its about 1"x1" and its silver with 3 prongs commin off it. its right under the glove box. im guessin ur truck is mid to late 70's model. that is most likely fried too. itll run u about $20-$30 to fix it and not too much time. hope that helps.
Old Dec 6, 2003 | 12:38 AM
Barleypop's Avatar
Barleypop
Also make sure that the blower hot lead is not pinched between the dash and any metal supports like my friend's was. Have you done anything under the dash later like a a new stereo or glove box repair, or duct work? If so check the path of the blower red or orange power lead for pinch points.
Old Jan 11, 2004 | 01:10 AM
79pos's Avatar
79pos
I had the same problem, But I had just replaced the altenator light and was messing around behind the dash when it quit working.
I figured it was just wires touching so I moved the wires and it started working again and hasn't messed up since...
Hope maybe this helps. It also takes 35amp fuses(just in case the lettering was rubbed off the fuse box.
madman1966
15
Sep 27, 2013 12:25 PM
FrankTheF100
Apr 27, 2013 02:51 PM
jc1416
Aug 1, 2006 12:39 AM
4dtough
Oct 28, 2005 12:45 PM
mattisjd
1983 - 2012 Ranger & B-Series
Oct 13, 2004 09:56 AM
