5th wheel stabilizers
Old Dec 23, 2023 | 09:20 AM
  #31
Johnny F2 fiddy's Avatar
Johnny F2 fiddy
I have a Momentum with 6 hydraulic legs, and that thing is solid as a rock! I do use some homemade larger blocks, but sometimes they are too tall for the front and the front cant drop down far enough to do it's auto-level.
Old Dec 23, 2023 | 10:48 AM
  #32
BWST's Avatar
BWST
Got Data?
I'm finding the same to be true for this Solitude I picked up last weekend. The 6 hydraulic legs of the Lippert Level Up system seem to lock it in place well. Laying in the bed with my adult kids walking around in the trailer will be the litmus test.
Blocks for the rear 4 jacks to keep leg extension to a minimum helps, and now considering a pair of recycled tire snap-pads for the front legs, since the landing gear does not extend much on a level site due to the drop frame.
Thinking now the Steadyfast system will stay on the travel trailer and be sold with it.
Old Dec 23, 2023 | 11:52 AM
  #33
kshoop1958's Avatar
kshoop1958
I've got 10" of plastic at each corner, still get a fair amount of side to side wobble when moving about the interior. Those side to side stabilizers seem to be what I need.
Old Dec 26, 2023 | 10:37 AM
  #34
MKrenn's Avatar
MKrenn
Originally Posted by kshoop1958
My 31 footer’s scissor jacks are located fairly close to the back, maybe a foot or two from the bumper. That’s why I’m thinking about sticking an extra pair about halfway between the existing scissor jacks and landing gear, just to see what happens.
I tried metal x-chocks between my wheels but the ones I bought wouldn’t fit, so I’m using the cheap plastic ones with a single screw adjuster. Those don’t seem to do much, but maybe they’re not as effective.
I could have sworn you had stabilizers @scraprat, but I was kidding anyway!
Hey Ken, I installed a 2nd set of scissor jacks right behind the back axle on our 42' Impact. It did help a lot on front to back and side to side movement. You will have to play with the adjustment with both the far rear jacks and the ones near the back axle in order to achieve what your looking for. Pretty cheap upgrade and I would suggest not mounting the ones behind the back axle until you find your sweet spot.
Old Dec 26, 2023 | 11:09 AM
  #35
kshoop1958's Avatar
kshoop1958
Good to know, thank you!
I'm still looking and found two more store-bought gadgets that might work. For the front landing gear, MORryde makes this x-brace
Amazon Amazon
that would work under my back bumper. I also found a bunch of videos for a home-made system that uses 2x4s and a ratchet strap.
I'm probably over thinking this as usual, sure do appreciate the tips though!
Old Feb 24, 2024 | 03:16 PM
  #36
Fox-BLUE1's Avatar
Fox-BLUE1
I have used these for every rig I’ve owned. A little redneck but I feel they work really well. I usually paint them with a truck bed coating. I just made these since we got a new fifth wheel and haven’t had a chance to spray paint them yet. They do take up room in the storage bay, but for the cost and stability, I’m a fan. I have a set up front too.
Old Feb 25, 2024 | 06:41 PM
  #37
kshoop1958's Avatar
kshoop1958
Yes sir, those are the ones I've seen!
Steve
Jul 19, 2022 10:07 PM
idealtrucks
Jan 7, 2022 06:06 PM
tojoski
May 9, 2011 09:30 PM
mikedeason
Sep 29, 2005 10:54 PM
