egr fault
Old Apr 25, 2023 | 09:19 PM
bompa's Avatar
bompa
3rd Gear
egr fault
Code reader gives me an EGR pressure feed back fault. Does that mean the EGR valve is history?
Old Apr 25, 2023 | 09:48 PM
Ronniewhite's Avatar
Ronniewhite
what vehicle do you have? What's your code? Sounds more like the DPFE sensor.
Old Apr 26, 2023 | 09:06 AM
manicmechanic007's Avatar
manicmechanic007
It most likely means your DPFE sensor is kapoot
There are a few quick pinpoint tests you can perform
None of us can be of much help not knowing what you are driving or the exact code
Pinpoint test steps have you checking the hoses back and forth from the EGR tube /manifold to the DPFE sensor and then some voltage tests
You need the exact code so you do not end up chasing your tail on the diagnostics
Good luck
007
darrellbarnes
Sep 1, 2015 02:36 PM
pile_53574
Nov 16, 2013 04:10 PM
budlightman11j
Mar 30, 2012 09:10 PM
chrisbraziel
Sep 20, 2010 08:22 PM
signtist00
2004 - 2008 F150
Aug 25, 2008 09:15 AM
