Hey guys! My work recently bought an old F700 work truck and i'm having trouble decoding the vin number and its showing D as the engine code but that's not matching with anything. I was hoping someone here can help shed some light on it. Any help would be appreciated!
I told my boss if the company ever sells it i'm going to buy it, ditch the work equipment in favor of a regular bed to have a very short frame, single cab short bed F700 dually. Would be a blast.
Hey guys! My work recently bought an old F700 work truck and I'm having trouble decoding the VIN and its showing D as the engine code but that's not matching with anything.
Welcome to FTE
F70 = F700
D = 330 2V Heavy Duty FT engine
V = Kentucky Truck Assembly Plant
H8?9?? = 1970
132" Wheelbase
M = Wimbledon White
F714 = F700, 25,500 lbs. GVWR
4 8: 4 = Charcoal Black Kiwi Vinyl & Charcoal Black Diamond Basketweave Vinyl // 8 = 81A Standard Cab
No TRANS code - Domestic Special Order
HQM: HQ = Eaton model 17121 Single Speed Rear Axle // 7.17-1 // 18,500 lbs. Rear Axle Capacity // M = Ford 7,000 lbs. Capacity Front Axle with Power Steering.
25,500 lbs. Gross Vehicle Weight Rating
164 net HP @ 3,800 RPM
240275:
24 = Jacksonville FL Ford District Sales Office, where the original selling dealer ordered the truck from.
0275 = Domestic Special Order number, truck ordered special by the original purchaser, not "bought off the lot."
Original purchaser specified a transmission that was not factory installed in F700's, making this truck a Domestic Special Order.
You'll have to look at it, see if there is an ID plate or numbers on the case. Then post what you find.
