NEED HELP !!
Refer to the other to see what I replaced I and what I’ve done to the truck already at this shop. The one thing that might be related is when I started to have a hard start issues on the rear tank, I noticed that the front tank was not working well either and then eventually the front tank just died no start at all on the front tank. I never had issues with the front tank from day one and by the truck used until just now.
The tech says when the hard start rears it’s ugly head from the rear tank the gas is gurgling as if it has air in it too.
When it starts “clean” it’s beautiful. The engine will run as smooth as a kitten purring and when you shut it off. Sometimes it starts right up and sometimes it takes about 10-15 minutes before I can get it going.
So the shop with our discussion with the mechanic decided to drop the front tank to see what’s happening. Could the hard start just running off the rear tank be related to the front tank stopping to work?
truck is a 92 F 250 5.8 motor 2wd auto
don
If I saw it it went right over my head. This makes it kind of sense I’ll bring this up to the tech first thing in the morning. I do know that this Maria does not have that valve system which some trucks have that both tanks feed into. I don’t believe you’re referring to this. Thank you thank you thank you Don
trust me when I say this, I will slow down and pay more attention. Thank you so so much Don
Your truck has a high pressure pump assembly inside each tank. Each Fuel Delivery Module (FDM) has a pump, check valve (supply output) and a shuttle valve (return side). The selected tank will pump fuel passed the check valve to the fuel rail at the engine. The fuel will exit the return side of the fuel rail to the fuel pressure regulator then head toward the return side of the selected fuel tank. While the selected tank's fuel pump is running that pressure opens the shuttle valve on the return side so fuel will return to that tank. The unselected tank's check valve on it's supply side will be closed. With no pump running on this tank the shuttle valve is closed. Both of these valves prevent fuel from flowing into the unselected tank. Therein lies the problem when/if the check valve or shuttle valve no longer closes all the way. Fuel will leak into the unused tank. This typically will fill the unused tank eventually AND this diverted fuel flow can also decrease the fuel pressure at the fuel rail on the engine. It happens on this vintage truck frequently.
Example Fuel Delivery Module (FDM) on your truck.
thank you for the unsolicited diagrams. They are greatly greatly appreciated. Randy, if you and your family ever come to Florida you have a place to stay and be happy to give you a ride in my 897 hp 07 GT500
don
again thank you both, I dropped off the information that you posted Randy and that’s with a tech think he’s taking the tank down the front tank down and it’s gonna be looking at check valves
I will keep you both posted
don
don
I promised you I would give you an update once I get the truck back and I got it back today. I will let you know what was done to the truck but the truck is running real real smooth as I would expect. I had new spark plugs put in, new plug wires, new fuel tank selector switch which is why the front tank wasn’t working, distributor and rotor, distributor cap, PCV valve, air filter for the engine, fuel filter, ignition coil, electronic ignition module and that’s about it.
When they drop the front tank the tech said the check valve is part of the fuel assembly pump, you have to replace everything. You can order it piecemeal but my system isn’t that way. They kept the truck for an extra 3 days just letting it idle switching from front to rear and had no issues. The. Tach asked me to drive the truck for 4-6 front tanks with out ever going to the rear tank. Than he advised to than go to the rear tank and only drive it on the rear tank for the same cycle period. If no issues I should be good to go.
However, what you advised me was the check valve in the front tank in all probability is bad. So I am considering just having the the whole fuel pump assembly replaced even though the tech said to drive it. They think they got the issue handled. I’m not so sure. He also gave me a heads up which is the first I’ve heard of this I want to pick your head, he said these old trucks weren’t designed for ethanol fuels and that with ethanol in the fuel there’s going to eventually deteriorate the fuel lines in the seals. Have you heard of this before ?
Don
not good!
well I did some research and found that certain gas stations do sell non ethanol fuel at the pump. 4.40 something like that not cheap but doable, just filled the truck up and will start using it when I have to refill
don
