The big factor most people overlook is the storage card that can go bad after a while with use and also being exposed to all that heat being high up in the windshield. Make sure you get a high quality name brand storage medium from a reputable seller that is designed for high volume writing and meant for media strorage and retrieval. You don't want to find out that your card didn't capture the video because the SD/MicroSD/etc failed. There are a lot of counterfeits out there to make things more complicated.
Originally Posted by Poncho450
I don't have a rear cam due to the rear window graphic on the truck. But I have Rove R2 4K in both the truck and my Mustang. The best of the 3 or 4 brands I've used over the years.
If the SD card gets full the display tells you and asks if you want to reformat.
don't most dashcams have the ability to loop so it it just writes over the oldest files? it's the most recent clips that matter. Having to keep checking to format seems tedious over the long run.
[QUOTE=twobelugas;20820242]The big factor most people overlook is the storage card that can go bad after a while with use and also being exposed to all that heat being high up in the windshield. Make sure you get a high quality name brand storage medium from a reputable seller that is designed for high volume writing and meant for media strorage and retrieval. You don't want to find out that your card didn't capture the video because the SD/MicroSD/etc failed. There are a lot of counterfeits out there to make things more complicated.
It is very true - the cards in phones I've noticed they even are not as durable as they used to be - maybe it is quality issues, or just a byproduct of the higher capacities in a smaller form factor. The other concern I have is getting video in cases where someone either breaks into the truck, or worse. I would like to at least be able to have video to hopefully catch the people responsible. That said, it seems you need both a plan for the LTE, as well as possibly pay a fee for the camera recording services (like Blackvue) which can get spendy. Maybe I am overthinking this, but easier to make an informed decision once than to make a purchase again.
I certainly thought that I'd read that someplace about my cameras. But every now & then I'll look up at the display and instead of seeing the live view I see a blue screen that tells me storage is full and asks if I want to reformat. I don't know if maybe I've overlooked something in the settings. It hasn't bothered me enough to dig into it deeper.
Will do. What i am not a fan of is the in-car mic recording. Who knows what I will say, and there are enough devices recording us (self-surveillance) where that is not my goal.
My 3 year old 1 channel dashcam has the option to stop audio recording.
I think it comes down to the limitation of the current widely used medium, modern solid state drives have a limited life cycle count so it is always better to have a bigger drive so the user can minimize the write cycles, and they do go bad after a few years or so if not regularly used.
A few years ago it was discovered that some early teslas’ main data drive would go bad due to exceeding certain write cycles and the temperature variation that automotive use subjects the cards to. Jut nature of the beast.
I've had a few brands and I think that most of them have the option to turn off audio record. Like many other gadgets just have to scroll through the settings to find it.
If you don't have your audio on you can't prove when you or someone else hit the horn. If that, for some reason, becomes desirable. You can always edit out whatever audio you might want to later.
It always amazes me on crash videos how many people fail to use their horn in appropriate situations.
Good to know, I'll have to check mine occasionally.
I have a Viofo A229 2k front and rear camera, no LTE. It works well, really no complaints. If you want to review video a lot, swapping out the video cards on mine would be the easiest way. I just wanted something that is recording all the time. With a 256 Gb card I think I have the last five hours of video available when the truck is on. When parked it takes stills and video when is senses a shock.
I dont want to review video ever. However I have had a few times now where both my kids have said will you check to see if you got this on camera. Both times the camera hadnt been recording for months. Since that time I tend to verify every 3-4 months to make sure they are recording. I cant say I have had good luck with that. I too wanted something I could leave in there and not worry and I have not had that to be the case.
I have been happy with my BlackVue, it is over a year old and still works well. It was a dual channel 4K DR900X model. Easy to access videos and it paid for itself last year when we were hit on the interstate. The insurance company appreciated the video and when the State Trooper came to me and said "I am being told you hit the other driver" the first thing I said is lets look at the dash cam and see who hit who. Cleared it up pretty well.
I never gave this much thought, but that could explain why my 2015 Garmin Nuvicam prompts of card issues every so often.
Even the cheapest DC I have used had the loop function to rewrite over old data, and they all have the ability to mute the mic since there are states out there where it is illegal to record someone without their permission, so the ability to mute is a must have.
It amazes me how many use the horn when it wont do a damned bit of good. Crash, horn, WHY? Too late, they already crashed. SMH.
I like to believe that a recording feature isn't far from being standard/optional equipment pretty soon right from ford, since we have cameras all around most vehicles anyways. Cant be soon enough for me.
When I had my 2012 F250 parked on the curb at my son's house, somebody sideswiped it during the night. No dash cam.
I've had a dual channel BlackVue in my F350 since the day I bought it in 2017 but haven't had any issues other than a "mechanic" at the Ford dealership that refused to work on my truck unless the camera was unplugged.
I have mine on a battery under the passenger seat, which is wired into the fuse panel behind the kick panel. Running wiring was very easy all around.
I bought a commercial Fleet Truck dashcam,
the View Screen is large, and can Record up to 4 cameras.
I put one camera over the rear Ramp door on our Toy Hauler,
intended to put the other one on the windshield of the truck,
but it never got installed.
Love the ability to see behind me for more than 2,000 yards,
if I see traffic getting backed up behind me, and when I can find a place to pull over, I do and let them go.
I'm retired, when I get there, will be soon enough.
