OBD2 fuse keeps blowing
Old Apr 16, 2023 | 08:06 PM
Brian 99 Ford's Avatar
Brian 99 Ford
1st Gear
Hey all. Have a 99 F250 7.3L using as a work truck. Wanting to plug in a gps device to track the miles through the obd2 port. Not getting power and after doing some digging the fuse was blown. Put a new one in and it pops right away. Unfortunately I don’t have a lot of experience diagnosing electrical problems or tracing shorts. Any input/advice would be greatly appreciated.
Old Apr 16, 2023 | 09:24 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Without looking at a diagram, I am fairly certain the OBDII port shares a fuse with the 12v power port. You could get to the harness/connector behind the power port and disconnect it to see if that changes anything.
First, try to verify this fuse share via the manual or a search on the FTE.
You may have a frayed wire shorting itself under or behind the dash. You could also try to visually inspect the wires from the two areas, but unless you get lucky will likely need a multimeter.
Old Apr 16, 2023 | 11:04 PM
Kwikkordead's Avatar
Kwikkordead
Yeah, run a dedicated 12g wire to that socket with a 15 amp fuse. If it blows that fuse, there's a problem with the device.
Old Apr 17, 2023 | 06:24 AM
FordTruckNoob's Avatar
FordTruckNoob
Here is the wire diagram for good measure. There are only two things on that fuse so it should be easy to find the short.
drivefaster35
Mar 3, 2017 11:13 AM
Supercab
1983 - 2012 Ranger & B-Series
Sep 26, 2015 08:13 PM
vebosie
Mar 7, 2012 07:08 PM
ncguy23
Electrical Systems/Wiring
Jul 27, 2007 03:33 PM
