Bed removal??
Old Apr 16, 2023 | 05:40 PM
F-250 restorer's Avatar
F-250 restorer
Bed removal??
Hey guys. I'm alone and trying to remove the bed from my truck. Been trying to rig up my engine hoist, but finding it darn near impossible.
Does anyone have an easy system to do this?
Old Apr 16, 2023 | 05:47 PM
5851a's Avatar
5851a
It may be in search but I think it involves at 2 friends or a wooden H frame somewhere over wheel house area.
Old Apr 16, 2023 | 07:08 PM
tbear853's Avatar
tbear853
I saw a picture somewhere of the lift chain hooked to a 4x4 cut to fit side to side under the bed rail lip there about center.
Google... removing truck bed with engine hoist ... lot of results, videos, pics there.
This is the thread I was recalling I think.
removing bed from truck - Ford Truck Enthusiasts Forums (ford-trucks.com)
Old Apr 16, 2023 | 07:25 PM
mwoj's Avatar
mwoj
Ratchet straps to the 4 corners. Cut a 2x4 to wedge between the bed walls above the wheel well.
Old Apr 16, 2023 | 08:53 PM
flowney's Avatar
flowney
Remove the tailgate and use four of the mounting holes to plave lifting rings. A standard 2 ton cherry picker (engine lift) will work especially if you extend the arm a few inches beyond the longest (1/2 ton) setting (no retaining bolt).
Old Apr 16, 2023 | 09:11 PM
F-250 restorer
Excellent! That photo shows the same hoist that I have. That proves that I can do it. I will use the 2x4 system, and will lengthen the lift arm a few inches first. Thanks to both members for the info. K
Old Apr 16, 2023 | 09:28 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Yes bump bed but you get the point.
How mikeo0o0o0 rigged it to weight it. 397 lbs.
Order 4 door dash meals set up at the same delivery time and make sure there is 4 big male delivery guys and have a beer and pizza handy.
Old Apr 17, 2023 | 08:43 AM
speedfreak78's Avatar
speedfreak78
This is the way. I built a similar "H" frame out of uni-strut and mounted 2 "J" hooks on the center beam I can attach an engine leveler too so I can adjust the bed as I lift it. Just slide the ends of the "H" under the bed rails on each side and C-clamp them on. I drilled an extra hole in my engine hoist boom so I could extend it about 6" further and put 4-6 cinderblocks on the back of it for counterbalance. I can move the hoist with the bed lifted, but it's really sketchy, so I lift the bed and drive the truck out from under it ,then put it down on stands or dollies. I've removed/installed the beds on my project truck and my DD multiple times this way just in the last year or so.
Old Apr 17, 2023 | 09:59 AM
F-250 restorer
Thanks, guys! I'm back at it today. My new q. panel comes in a few days so I want to have the old removed and ready.
UMDSmith
Oct 14, 2009 12:02 AM
Tedybear
Dec 13, 2007 08:20 PM
351beast
Nov 10, 2006 05:57 PM
dtony
Jun 6, 2005 12:18 PM
murphy
Jan 3, 2004 06:57 PM
