So, my mileage has been going steadily down for a couple months. From about 17 to now, 12 MPG. My truck is a 2018 F150 with the 2.7. 4X4 crew cab. 6 inch lift and 35 inch tires. I got a check engine light today with P0630 and U0422. Any ideas?
No. It's stock as far as I know. I got it a year old with the 6 inch rough country lift and 35s already installed. It was great till a couple months ago.
?? Google the interweb with codes and F150. There are various good reading threads. A tune is one culprit, that's why I asked. Even changing the tires size in the computer causes it, and yours does have modifications, hard telling who has played in the computer. It might be easier to take to a shop with proper diagnosis equipment rather than start throwing parts at it. Good luck.
It appears to me based on the 90 seconds of research that the first code has it's roots in the effort to change the tire size by telling the computer it's a different truck with a different OEM configuration--so the speedo will be correct.
The second code is the result of the lift. Some sensor is now in a cold, dark, unfamiliar place--or naked and alone in the open--and it is now afraid and can't talk to the computer like it used to.....
