1971 F600 decode
(another) 1971 Ford F-600 VIN plate decode:
Hi there everyone -I've never posted on a forum before, and I hope I'm doing this right.
I need some help decoding the VIN on a 1971 F600 that I'm interested in buying. Some of the info is obvious, as it's listed right there on the plate (for example, gvw = 24,000 lbs, hp = 182 @ 3800 rpm, etc,) but other things like trans, axle, engine, etc. I can't figure out. This vehicle is an ex-municipal rescue truck with only 13,700 miles on it. The current owner bought it from the town in '95 and didn't use it much - it pretty much sat in his large equipment barn (he's a farmer). It has surface rust underneath, some body rust here and there but overall, it's a solid piece of equipment.
Thanks in advance for your help!
Decode Your '61-'66 Ford Truck VIN - FORDification.info - The '61-'66 Ford Pickup Resource
Good luck.
E = 361 2V FT gas V8
C = Ontario Truck Plant
K50429 = 1971 numerical series, November 1970 production
174 = 174 inch wheelbase
No color code--truck is a special order, so color was probably part of that. The red looks to be a repaint based on the overspray on the tag.
F615 = F600 gas, 4x2, 24,000 lbs GVWR
438
4 or 43 = Black vinyl
8 = Standard cab without back of cab equipment. (Cab and Chassis)
M = Clark model 285V five speed direct transmission
54D
54 = Rockwell model H-170 single speed rear axle, 6.83 ratio. (Capacity at least 17,000, max 18,500. There is a plate on the housing with that info)
D = Ford-Rockwell (Timken) front axle, 7,000 lbs capacity
24000 = 24,000 lbs GVWR
182 3800 = 182 certified net HP @ 3800 RPM
110258
11 = Boston District Sales Office
0259 = sequential special order number.
Other than color, everything else is seemingly there--engine, trans, axles.
Let me know if you have questions or something doesn't line up.
Check your wheels:
https://www.ford-trucks.com/forums/8...l#post19892682
Brake parts EXCEPT DRUMS are available. (If you have Dayton style wheels there is hope for drums....)
I think I must be nuts for wanting this truck, but with less than 14,000 on the clock, I fell like I just can't pass it up. I want to use it as a work / transport vehicle for bringing all my gear up to Northern VT where I've started work on building a timber frame house. I see that winch coming in really handy! I didn't realize until I crawled underneath that it's run directly from the tranny. Very cool.
With the Dayton style wheel it is possible, although it might take some doing, to swap the rims out for 22.5" tubeless types.
Air brake brake drums are said to work but must be narrowed to work with your shoes. I haven't seen pictures of this, so beware.....
