1978 - 1996 Big Bronco
Dual exhaust
Old Nov 17, 2003 | 11:43 AM
Red_EB_Bronco's Avatar
Red_EB_Bronco
Dual exhaust
ok, new problem, I have a hole in my exhuast and would like to upgrade to true duals, what is the best system for performance and sound?
thanks, Charlie
Old Nov 17, 2003 | 12:31 PM
ctch88's Avatar
ctch88
I am also interested in this. The current stock y-pipe sounds good, but I would like to get more power if it is significant. I have heard that an h-pipe will actually produce more power than straight duals on the Winsor engines. Is this true?
Old Nov 17, 2003 | 02:16 PM
christop43's Avatar
christop43
There isn't a true dual system for the 87-96 Bronco's because it isn't legal to run true duals due to the fact that the exhaust converges into one before going through the catalytic converter. An exhaust shop might make up a custom system for you, but your better bet is to buy a new high-flow Y-pipe and replace the exhaust after the Y-pipe.
I know Greystreak and a couple of others have used a Bassani Y-pipe and are happy with it. Do a search on this subject in the Bronco forum, lots of good information.
Old Nov 17, 2003 | 02:23 PM
bobs75f-250's Avatar
bobs75f-250
"There isn't a true dual system for the 87-96 Bronco's because it isn't legal to run true duals due to the fact that the exhaust converges into one before going through the catalytic converter."
I'm not sure about that, because where I live, you don't even need a catalytic converter. So check your local laws and you may find you can get away with some stuff.
Old Nov 17, 2003 | 02:27 PM
christop43's Avatar
christop43
Bob-
You might be able to get away with it, but I am talking Federal Law, which pertains to you too.
Old Nov 17, 2003 | 02:32 PM
bobs75f-250
Is that a federal law? I don't really know much about all the laws, but my friend had his exhaust done professionally, and they told him that he would still pass inspection without a catalytic converter, so I figured it was a local law. Perhaps I'm wrong.
Old Nov 17, 2003 | 03:13 PM
3broncocrazy's Avatar
3broncocrazy
Yep,
Federal Agency EPA - Clean Air Act. Read it in your spare time........
Old Nov 17, 2003 | 03:37 PM
JBronco's Avatar
JBronco
All they do is look to see if you have one (or two) cats. If you put gutted cats on there and your emission is low enough, you will pass.
If you want true duals, put a "fake" inline cat on each side and it will pass, as long as the emission is low enough to pass.
Your emission might be low enough without visible cats, but you will fail the visual test for not having them.
Old Nov 17, 2003 | 04:43 PM
Gacknar's Avatar
Gacknar
I have to pass Emissions where I live.
If you go to a custom shop, they can run true duals with 2 cats, one on each pipe.
That is as long as the original cats have been removed or are no longer performing properly.
And when I say custom shop I dont mean midas, thats a retail shop.
I have never seen a car with a hollowed out cat pass emissions.
Old Nov 17, 2003 | 04:52 PM
84bronc's Avatar
84bronc
I don't know about all these y pipes, and cats and stuff, but I do know this, Do not have them exit out of the sides like behind the rear tires. I have it like that and everytime I put down my rear window I get fumes like crazy. I like the smell of gas, but not like that. Just my 2 cents.
Woody
Old Nov 17, 2003 | 04:56 PM
3broncocrazy
Also I think there is a damaged clause.........Take a hammer after the original
Again the custom shop, beeleave me, knows the law.
Old Nov 17, 2003 | 05:17 PM
89broncobob's Avatar
89broncobob
i did it my self .headers ( longs is what i used ..i got a good deal on them then i ran the pipes to 2 of the new cherry bomb muff's.
then straight out the back ..and man it sounds mean ..not to load
but a nice tough rumble..i love it. and have much better performance..I finally got to use my new mig welder.very happy.and in my county in florida there is no emisions checks..How ever if you get pulled over bya state trouper i will get a ticket .but o well i will take the chance..lol good luck
Old Nov 17, 2003 | 06:15 PM
christop43's Avatar
christop43
Old Nov 17, 2003 | 08:56 PM
broncobillybob's Avatar
broncobillybob
darn. i was told an h pipe wouldn't fit under my bronco- was i swindled? -wb
______________________-
'93 bronco xlt
apparently coulda had true duals
Old Nov 18, 2003 | 10:46 AM
BroncoRoadKill's Avatar
BroncoRoadKill
You know if you have the pipes exit out the back, your rear glass is gonna get black from the exhaust. Also if you open your back windoe while driving your gonna get all the exhaust into the cab.
Just lettin you know.
