DIY wiring harness replacement
Old Apr 13, 2023 | 12:43 PM
FiddlyThings's Avatar
FiddlyThings
I apologize if this is searchable or a FAQ, I promise I searched!
I'm considering rewiring my 76 F150 for the usual reasons. Shops say that's about 80-100 hours of labor, so at that cost I'm considering doing it myself. A few questions:
1. Am I crazy?
2. I assume I could do it in portions, like do the lights, then do under dash, etc? That way I can do it on weekends and still use the truck.
3. Again, am I crazy?
Thanks for your input here - I suspect 1 and 3 are yes, but I'll do it anyway to avoid the massive labor costs.
Old Apr 13, 2023 | 01:15 PM
casetruck1's Avatar
casetruck1
Its not too bad and most kits come with good instructions. I think for probably what they would have charged you it makes me think I should start wiring hot rods at home. LOL.
Old Apr 13, 2023 | 01:27 PM
FiddlyThings
Thanks! I'll probably order one today then. Most shops are saying 80-100 hours at $100/hour... I'll try it myself to save $8-10k.
Old Apr 13, 2023 | 01:30 PM
casetruck1's Avatar
casetruck1
Wiring takes a lot of patience. You can mess some stuff up quick if you don't take your time and hook everything up correctly but if you follow directions and have basic understanding of how voltage flows and has to have grounds then you will be fine.
Old Apr 13, 2023 | 02:16 PM
5851a's Avatar
5851a
What exactly is the problem with your wiring?
Old Apr 13, 2023 | 02:20 PM
beardedcap's Avatar
beardedcap
If you do it get the American Autowire one and not some painless or kwikwire one size fits all kit. And save all of your connectors, don't rip all of the wiring out at once, do it in sections and match it all up.
Old Apr 13, 2023 | 02:40 PM
FiddlyThings
Weird shorts when driving, vibration-related. The cause is multiple previous owners have left many cut and reconnected circuits, all without soldr, sometimes just lightly twisted, sometimes with scotch tape, and a horrific rats nest under the dash. Sockets need replacing, figured I should run new wires while at it, then started thinking about actually replacing everything and starting from a known-good state.
Old Apr 13, 2023 | 02:41 PM
FiddlyThings
Noted! I see that Painless has a vehicle-specific kit with Ford switches, etc as well now. Def will get a vehicle-specific kit rather than universal.
Old Apr 13, 2023 | 04:57 PM
nevinsj's Avatar
nevinsj
I just finished using american autowire and it was very user friendly and they have great tech support. You will need a couple of connectors (upper dome light harness, and connector for neutral safety switch) from your original harness. I installed digital dakota gauges and vintage air as well as running MSD ignition, which they have instructions for. I also installed 3g alternator and got the AAW adapter for it.
Old Apr 13, 2023 | 07:36 PM
FiddlyThings
Cool - how long did it take you if you don’t mind my asking?
Old Apr 13, 2023 | 08:26 PM
FordEdsel75's Avatar
FordEdsel75
I used the American Auto wire kit. It only took me one weekend. It was well worth the money. All wires are labeled and it was extremely easy.
Old Apr 13, 2023 | 09:43 PM
nevinsj's Avatar
nevinsj
I dragged it out working on it during the week about 4-6 hours a day for about 4-5 days. That was the entire AAW kit nose to tail as well as wiring the vintage air, new retro sound radio and digital dakota gauges with proper clamping, spiral wrap and good grounds.
Old Apr 13, 2023 | 10:52 PM
FordEdsel75
It gives you options too for the popular mods like 1 wire alternator and hei distributor. I used an hei but have the stock alternator and external regulator.
kdaug5
Oct 29, 2019 10:29 PM
77_150
19
Aug 8, 2013 09:26 PM
LIF150
Jun 13, 2010 09:16 PM
parr4
Apr 11, 2010 12:04 PM
