Ecm Chinese duraspark replacement testing
Old Apr 12, 2023 | 12:04 AM
Daltonandthedentside's Avatar
4wd Low
How can I test my ecm with a multimeter to confirm it’s good or not?
Old Apr 12, 2023 | 08:44 AM
440 sixpack's Avatar
440 sixpack
If it runs good it is good. and you should always carry a spare.
Even the Motorcraft ones are chinese now I don't think you can buy a quality one. but that goes for all the ignition systems you can buy for older rigs.
Old Apr 12, 2023 | 10:52 AM
4wd Low
Doesn’t run at all, rather I’m getting a lot of “bad out of the box” parts or I’m missing something, getting signal to the coil, couldn’t check anything while cranking, will bring my helper out today to test the whole ignition.
I’ve also cruised through about 4 starter solenoids, 1 has been bad before installed with continuity between the ignition post and battery post, and the other 3 will crank by key initially, and end up failing, some failing in different areas than others, is it a possibility it’s a problem on my end? The most stress I put them through would be bridging battery post to start post while being jumped by another vehicle, any tips would be great
Old Apr 12, 2023 | 01:57 PM
440 sixpack
I got 2 bad pickup ciols in a row, Standard brand. you might check that.
The chinese junk we get now will make you pull your hair out I feel your pain. and nearly all brands are the same junk in a different box. I try to buy NOS parts off ebay when I find them.
Old Apr 12, 2023 | 02:11 PM
4wd Low
do you happen to have a good way to test if an ecm is good or not? As well as the pickup coil? Everything else is pretty straight forward for me, just stuck on those 2
Old Apr 12, 2023 | 03:31 PM
440 sixpack
The only way to test the ECM I know of it to try another. the pickup coil you can test but I've never done it, I just replace it.
Maybe someone here knows how to ohm it out.
Old Apr 12, 2023 | 07:20 PM
460me's Avatar
460me
This should be it
purple and orange wires on the distributor side of the harness, between roughly 450 & 650 ohms. I ohm out 2 from NAPA, both with in specs. Both idled and that was it, give it throttle and it fell flat on its face.
Old Apr 13, 2023 | 11:18 AM
5851a's Avatar
5851a
Best to get the modules and solenoid's from salvage yard cars. They used them on most Fords part way through the 80's on about everything. Escorts, Pinto's Lincolns. AMC's/Jeeps were using them into mid eighties. Just look for the blue strain box. Don't look for new shiny replaced parts. Look for a car an accident put it in salvage. Probably running when it was hit.
Old Apr 13, 2023 | 12:53 PM
Crop Duster's Avatar
Crop Duster
You can't really, the things are solid state.. Even the service manuals say to replace with a known good module. After you have checked all the wiring,
I quit using Duraspark ICU's 30 years ago. I used regular Mopar boxes until those became chineseium. I use these now, never had one fail. But just in case I have a failure I carry a GM 4 pin in the glove box to get home with.
FBO Ignition ECU Module HRR688 Dodge Plymouth Chrysler all V8 Mopar engines 610877674138 | eBay
Old Apr 13, 2023 | 03:23 PM
scottscott's Avatar
scottscott
This item says it will test the Ford ignition module: https://www.ebay.com/itm/234473688331?epid=1442297919&hash=item3697b88d0b:g :4~kAAOSwSS1iNfXK&amdata=enc%3AAQAIAAAA4HYCHeuiuZT 13q5TDcR%2FiWk28okq48YjcbKtKmeadSZH%2FmrJGSe4QIDuJ nzaehSIDKECRzNNx%2FoRAsRsu5rhase%2BcBjPSS2uqEV8SaV l7osmXqUYe84Sg3eihcDdCUWQGuAAayDGdmjmvSqpavhEkuyfZ 7FiKI9C6BgULKkc9XaZjJGO%2FIIm1UJm%2BGzFz6cucAmd1J6 O46Q2JKzzYiSnlCGErZaQkd%2FOa0cepyqP3IhlJRIo4esJA RttkHz187O96hR3W4oNMwDW8rTEsX18kA6FCJV4FxK1onMSZ1Z o%2BW%7Ctkp%3ABFBMsvq-xO9h
If you check the pickup with an ohm meter, heat it with a hair dryer & check it when hot, as well as cold. Many will pass when cold, fail when hot.
Has anyone ever tried wiring a chevy HEI module into the Ford wiring?? I've seen diagrams for this online, but never had a need to try it.
Old Apr 13, 2023 | 08:00 PM
speedfreak78's Avatar
speedfreak78
You can find old ICM testers on Ebay for like $50 sometimes.
https://www.google.com/search?q=vint...=firefox-b-1-d
There's also a youtube video showing how to set up a bench test of the whole system, you need a 12V DC power source and a 1.5ohm resistor
https://www.google.com/url?sa=i&url=...r4kDegUIARDMAg
Old Apr 14, 2023 | 01:40 PM
Crop Duster
I carry a GM 4 pin module that I have pre-wired in my glove box for emergencies. But my FBO box runs on a full 12V so it is just plug and go. If you replace a Duraspark ICU with one be sure and remove the resistor wire. Also, they get very hot, so it definitely needs a heat sink under it. You can mine some really nice heat sinks out of a dead desktop computer.
VanGo3
General Automotive Discussion
Jul 8, 2021 09:18 PM
Swaybar1
Jul 8, 2021 07:23 AM
Chefsteele
Jan 8, 2014 04:00 PM
foxracer800
13
Feb 18, 2009 10:13 AM
TwoF150
Aftermarket Products
Apr 30, 2003 09:46 PM
