2005 excursion limited
Old Apr 11, 2023 | 08:15 PM
bklynboy127's Avatar
bklynboy127
4th Gear
I have an electric issue . Window , radio glove box and map light not working. Checked fuses checked relay. Good. Trying to find out where the power comes from on the wiring side of the fuse relay box. I even changed the fuse relay box. I know it is an 8 pin connector the is the power but i do knot know which one. Any help greatly appreciated
Old Apr 12, 2023 | 11:23 AM
Smoothwater's Avatar
Smoothwater
Relay is built into speedo.
Look up Dash Medics . Can jumper the relay for a short term fix but will drain battery if let the Ex sit with it jumpered.
Old Apr 12, 2023 | 12:35 PM
John in OkieLand's Avatar
John in OkieLand
on my Excursion, the cluster panel relay was stuck Closed....
over 2 days, no issues.
on day 4, the truck would not start
kmcmurph
Mar 4, 2020 11:47 PM
jswartz84
May 19, 2013 02:50 PM
pooch
Electrical Systems/Wiring
May 17, 2009 08:25 PM
RAMPAGE_F350
Jul 13, 2008 01:40 AM
