2001 Excursion Towing Relay
Old Mar 3, 2020 | 12:18 AM
kmcmurph's Avatar
kmcmurph
I am looking for some guidance. I have a 2001 7.3 and have no power to the hitch to charge the camper battery. I have fuse 115 under the hood (30amp mini-max) which is good, but no power at the hitch. Am I missing a relay somewhere, one that's stuck or bad?
Old Mar 3, 2020 | 07:05 AM
projectSHO89's Avatar
projectSHO89
Check the little relay box next to the underhood distribution/fuse box. There are spots in it for the relays for the trailer charge and trailer backup light circuits.
Note: If your truck is a 4x4, there will be a second box for the transfer case relays.
Old Mar 4, 2020 | 11:30 AM
kmcmurph's Avatar
kmcmurph
The owners manual only references the fuse location 115, it does not mention relays. So I am wondering if the power passes thru a relay going to the bumper because fuse 115 is hot all the time.
Old Mar 4, 2020 | 01:31 PM
projectSHO89
Yes, the power has to pass through a relay (which is not covered in the manual). See my previous reply
Old Mar 4, 2020 | 11:47 PM
kmcmurph's Avatar
kmcmurph
Ok, now I am following you. Thanks.
bc75
Jan 11, 2018 08:56 AM
superdutyf450
Nov 24, 2014 09:32 PM
adam62
1997 - 2003 F150
Jan 10, 2011 06:32 AM
eicht
Nov 27, 2009 10:48 PM
Luke80916
Dec 29, 2004 05:57 PM
