Hey y'all, its a bit of a story so buckle up. Purchased a 1991 f-250 35w last year and has been problems ever since, testing sensors daily, trying to get it to idle, pass emissions, the list goes on. The head gasket blew and I took the heads off and replaced them, lapped the valves, and put valve shims in where needed. But recently the engine has been ingesting oil, a quart every 100 miles. Figured out that it was being ingested through the intake via the PCV I believe, it is a lot of oil to be ingested but I found a lot of oil in the upper intake manifold. Made a list and went from top to bottom. I decided to run a compression test, they are sitting around 60 PSI, I don't wanna tear it back down I am out of patience for this engine. I want to swap it with the 460, I know I will need a new transmissions, drive shafts, engine harness, and a engine computer. What do yall think? What all do you guys think i would need for a swap. Thanks!
If you are sucking that much oil via the PCV, you must have:
--an oil drain back problem.
--a bad pcv
--improper air flow for the pcv
Is your setup like so? You should have a "closed system" as illustrated. Air from the aircleaner housing goes in one valve cover, fumes etc are drawn out of the other one via the pcv to a port on the intake.
Why make life so much tougher? Just get a replacement 351W and be done with it.
I you want to do the swap: If you get the same model transmission you will not have to change the driveshafts. Do not use any of the donor engine's harness. Keep the harness that you already have. Extend any sensor wires as needed. Yes, you will need a computer for a 7.5L engine. You may need to remote mount the oil filter or use a 90 degree adapter. That may not apply for a F250/350.
As far as PCV valves are concerned be sure it is a genuine Ford part. Years ago I had a used 86 CV that would blow out a cloud of smoke every so often. I even changed the valve guide seals with with no improvement. I mentioned it to a Ford dealer shop foreman and he said to get one from the parts counter. Problem solved.
--a bad pcv
Awesome thank you! I recently replaced the valve, and the airway from the air box is intact and free of obstructions. What do you think would cause a drain back problem?
The PCV on it right now is a MircoGard from O'Riellys . So I found the donor engine and transmission its the M5OD I have the same one but for small blocks on the 351w right now, I was wondering about the transfer case I have on it right now, I will get the tag for it when I get a chance. I imagine the fuel system wont need to be changed its got the dual tanks. Do you guys think I would need new motor mounts? I appreciate all the help, none of my friends have done an engine swap this big.
Why would you not do that? Especially if OP finds everything intact? Way less trouble than fussing with splicing if the donor is the same year. Then all he does is plug in.
Because Ford changed many of the wire positions on the main connector between model years. If the donor is not exactly the same year then you will most likely have issues.
So my truck is a 91 the donor is a 92, worse comes to worse and the wires don't match up I will just get another harness, I imagine I can frankenstien it together. The only thing I am worried about is if there is something on the 351 that the 460 doesn't have or vise versa. I will look into the smog system when I get a chance.
Nothing is going to match up between 91 and 92 harnesses. You would best start looking for a 91 7.5L wiring harness. You may be able to use an engine harness between 87 and 91, but 92 was a year of big changes.
