Gear Ratio?
Old Apr 18, 2023 | 08:12 AM
Ford427Man's Avatar
Ford427Man
All I found on eBay is complete rebuilt units, or the same one I have now for 4.56 and up. I confirmed with support that I can move the innards, so I bought the empty carrier.
I think I have settled on 3.73 gears, with 265/75R-17 tires, this should have the RPM at 2305 @ 60 MPH. So now I need a different open carrier for the front because of carrier break, looking into that.
Old Apr 19, 2023 | 09:29 AM
Ford427Man's Avatar
Ford427Man
Are these gear sets correct for my '75 4x4 F250? I now have the correct carriers for 3.73 gearing. Any suggestions on alternative vendors?
https://www.summitracing.com/parts/sdh-76089x
https://www.summitracing.com/parts/SDH-22736-5X
Old Apr 21, 2023 | 12:21 PM
speedfreak78's Avatar
speedfreak78
According to their vehicle fit guide they should be right. I'd look at Rockauto, it looks like they have the same parts but a little cheaper, but they're gonna charge shipping so Summit might be better overall
IDK if it would've mattered, but they also list a Richmond 4.10 thin gear that would've worked on the rear 4.56 carrier.
Old Apr 21, 2023 | 02:53 PM
Ford427Man's Avatar
Ford427Man
Thanks, I will do a bit more shopping. I am nervous about trusting their vehicle fit guide, it said the brakes pads I ordered for my other PU ('75 F250 2WD) would work, they don't. Ford was nice enough to make some changes mid-year in '75, so you really need the VIN to get the right disc brake parts.
Old Apr 22, 2023 | 08:32 AM
speedfreak78
The PN's seem to cross-reference between summit and rockauto so they're probably right. If you want to be 100% on what you need, you need to get the B.O.M number that's stamped in the axle tube, or on the tag on the cover, and look it up on Dana/Spicers website. You're not dealing with Ford parts, it's a Dana/Spicer built axle, so year to year changes by Ford won't matter. The ring/pinions are all the same for all the high pinion 60's, you can even fit the "super" 60 gears from the Super Duty axle with a little work, which are stronger gears.
Old Apr 22, 2023 | 12:06 PM
wyrm73's Avatar
wyrm73
Edit: Disregard, had an option for an open front carrier. Missed the later post that you got one.
Old Apr 26, 2023 | 09:22 AM
Ford427Man's Avatar
Ford427Man
I purchased a D60 Powr-Lok carrier from JustDifferentials (Niitro Gear). I was offered a 5% discount, and after applying for that my order went in, without the discount. Mistakes happen, so I tried calling them about it. Was transferred to someone to deal with it, while leaving a voicemail the call was ended. Emailed them, no response, days later called again. Was told my email had been forwarded to someone. Waited, emailed again. As of today there has been no response.
OFLM
May 17, 2015 03:37 PM
almonyspm1
Oct 25, 2013 08:46 PM
bain_b
1983 - 2012 Ranger & B-Series
Jan 28, 2008 02:55 PM
cjben
17
Dec 18, 2005 09:44 PM
Big 89 Bronco
1978 - 1996 Big Bronco
13
Mar 15, 2003 04:03 PM
