P1211
Old Apr 8, 2023 | 06:01 PM
S-squatch's Avatar
S-squatch
P1211
History, installed new tune, and riffraff ocr. The highest tune is over 100. I am not going to leave it on this high, just testing.
Now I'm getting a P1211. Not all the time, but often enough. Short drive hard I might not get one.
yesterday I had on hot idle IPR at 35%. Today it is at 11%.
I am seeing spikes in the icp that don't seem to match rpm or IPR.
in one run I saw a psi of 3059, and a ipr of 37%. I try to save these but I have no idea where they are saving.
Before I go testing fuel pressure does this a sticky IPR?
Old Apr 8, 2023 | 06:05 PM
Tpayne621's Avatar
Tpayne621
1211 is a very common code with a hot tune and stock hpop when you get down on it. Stock hpop can't maintain the icp psi the tune is calling for. Likely there isn't anything wrong.
Old Apr 8, 2023 | 07:57 PM
S-squatch's Avatar
S-squatch
Thank you, good to know it's common. I dropped it back to 90 for more testing.
still seems strange yesterday my idle was in the 30ish%, and today it's 11. I don't know if this was happening before the tune, it has ran fine before and after.
Old Apr 8, 2023 | 08:00 PM
Tpayne621's Avatar
Tpayne621
Keep a eye on it and see if see anything or it happens more. Normal idle around 10-11% give or take a few. But oil temp can make it change also.
Old Apr 8, 2023 | 10:06 PM
udsuth78's Avatar
udsuth78
No other symptoms other than erratic sensor readings? I can think of 3 possible scenarios, dirty/sticking IPR, ICP failing reporting incorrect data, or the IPR is finding ground on it's own. If the key is on that connector is hot and the PCM controls it through the ground side of the circuit. So realistically any kind of short to ground between the valve and the PCM would fire the solenoid.
StrokerPains
Apr 16, 2020 03:24 PM
Keith Poole
Sep 30, 2018 03:58 PM
seijirou
Jan 1, 2017 10:17 PM
ChunderDownUnder
30
Apr 30, 2010 08:51 PM
unluckylow
43
Oct 13, 2005 03:22 AM
