Drive shaft length
Old Apr 6, 2023 | 09:11 PM
SumDayDryvr's Avatar
SumDayDryvr
Drive shaft length
A little background, we have exchanged the original rear axle in our 55 f350 with a Dana 60 from a 68 f250 and we have shortened the driveshaft. Here is where we need the help, I didn’t check the amount of movement allowed between the hanger bearing and the rear driveshaft slip yolk.
With the shortened driveshaft we have about 1/2 inch of space but don’t know if there should be more of an allowance. If you can help it will be greatly appreciated.
Old Apr 7, 2023 | 12:09 PM
52 Merc's Avatar
52 Merc
With a single piece driveshaft, the rule of thumb I've always been told, and have used, is to pull the slip yoke 1" out from bottom inside the transmission and build the driveshaft from that. I would assume that same amount of movement would be recommended at the slip yoke no matter if it's at the trans or the center carrier bearing. With only a half inch of adjustment, I would be concerned about bottoming out and damage with axle/suspension movement. I don't have a spec for that, and maybe others will have differing opinions. Have you contacted your driveshaft building company and asked for their recommendation or thoughts?
Old Apr 7, 2023 | 10:18 PM
SumDayDryvr
Thanks for the information. My driveshaft builder is a friend with a hacksaw and a lathe. We will get a professional welder to weld the driveshaft back together once we are satisfied with the length.
fords/harleys
Jan 29, 2015 02:03 PM
Sooper Camper
Dec 20, 2013 06:21 PM
Spitfire44
Jul 13, 2010 12:41 PM
Simple Man
Aug 29, 2004 03:55 PM
