am i missing something
Old Apr 10, 2023 | 08:59 AM
catastrophejustin's Avatar
catastrophejustin
Originally Posted by 69f100longbed360
here’s what mine looked like when I removed it maybe this will help.
Rear drum with axle removed
… did you ever remove the backing plates? I’m betting you’ve got it on the wrong side. If it was on fwd side on drivers side and you took that backing plate off and put it on the passenger side the adjusting hole would be in the proper place.
i went through that. if i swapped the backing plates the parking brake cable would be pointed out the back of the truck and the hole location would still be off.
Originally Posted by nutter3
good morning and happy Easter. Forget my last advice to turn the adjuster around. It does appear your backing plate is manufactured wrong. Did you ever have working brakes on this vehicle?
brakes worked before. i drove it around for awhile before tearing it down and never had a problem.
AppleTech
22
Aug 6, 2021 10:39 PM
crucialprospect
20
Jun 6, 2021 07:58 PM
UKPR1
May 31, 2021 03:17 PM
Powerstoke73
Jul 28, 2014 09:31 PM
John & Old Ford
Nov 23, 2012 09:50 AM
