Rear Brake Adjuster not adjusting - where am I wrong?
Old May 30, 2021 | 01:19 PM
UKPR1's Avatar
UKPR1
Hope everyone is having a reflecting and relaxing Memorial Day Weekend.
While my engine is out, I'm going back into my rear suspension and brakes. The first time around, I wasn't happy with the adjusting movement of the rear-driver's drum, but I let it be (dangerous, I know...) so I bought a kit and went back into the rear left again, and couldn't do any better the 2nd time, although I think I can describe what's wrong, I just don't know how to correct it. The adjuster lever is resting on the shoe and as such, won't engage the ratcheting wheel. If I pinch the cable and shorten it, it will then pick the lever up enough to engage the adjuster wheel. So...what am I doing wrong. Pictures below...good side then the bad side...
The functioning side
Lever is off the shoe
The malfunctioning side
Lever rests on the shoe
Thanks in advance,
Geoff
1969 Ford Ranger 2wd
Old May 30, 2021 | 02:02 PM
UKPR1's Avatar
UKPR1
The more I look at it...clue #2..? Who has noticed that the side that is misbehaving the whole assembly is rotated kinda clockwise? Could that be important?
Geoff
Old May 30, 2021 | 03:30 PM
Phantomtruck68's Avatar
Phantomtruck68
It appears that you have the brake shoes on the non working side reversed. The shoe with the shorter pad goes on the other side. Maybe that has something to do with the adjuster not working right.
After looking at it some more I am wrong.
Old May 30, 2021 | 06:52 PM
davelj's Avatar
davelj
Short shoe goes to the front. The hole for the cable guide is in a different place so the cable is slack.
Old May 30, 2021 | 07:22 PM
AKsilvereagle's Avatar
AKsilvereagle
Like others had posted, this is what the shoe assembly should look like (my 73 F100) :
I would also recommend applying a light coat of grease on the shoe adjusting cable and groove guide, the brake shoe pin mounts, and the retainers to slow down the corrosion and rust if one wants these parts to last much longer...
I would also at the very least - highly recommend applying anti seize lube on the brake shoe adjusting threads, both male and female if one wants this vital part to continuously work :
I also grease coated the base of the shoe mounting pins behind the backing plate to further slow the aging process, added a vinyl vacuum cap to cover and protect the bleed valve, and applied anti seize lube to protect the small mounting bolts of the wheel cylinders so they will not rust for easy distant future removal with no hassle :
I also lightly coated grease or anti seize lube on all mating surfaces where any one part has to move or any two parts that rub together to further the reliability of brake shoe assemblies.
Old May 30, 2021 | 08:08 PM
UKPR1's Avatar
UKPR1
Thanks, gents!! I'm not sure how that one slipped by me! I'll swap them tomorrow for sure and report back.
Geoff
Old May 30, 2021 | 08:39 PM
kenny nunez's Avatar
kenny nunez
Exclamation Rake spring
Picture #2 &3 show the spring from the lever to the shoe not installed right. The coiled end of the spring has to be in the hole and not hooked in the hole.
Old May 30, 2021 | 10:12 PM
UKPR1's Avatar
UKPR1
Got it. Will correct. Thanks.
Geoff
Old May 31, 2021 | 03:17 PM
UKPR1's Avatar
UKPR1
Firstly: Thanks to everyone who chimed in. Upon taking a good look today, the shoes were in fact oriented correctly with the "short" shoe in the front. The issue was, as Kenny correctly pointed out, the spring that hooks to the adjustment lever was not installed correctly into the shoe. This made the spring artificially long which created just a little extra slack in the cable. The other issue was that the cable corner guide had a tendency to pop out of its locating hole, which again, gave the cable just a little too much slack. Once I corrected the spring installation and made sure the guide stayed were it was supposed to be while wrestling with the springs, the lever is where it is supposed to be and functions correctly. Thanks Kenny and everyone!
Geoff
Michael Blackwell
Nov 17, 2020 04:24 PM
geetoe
13
Nov 24, 2018 11:04 PM
sere0501
Jan 18, 2015 09:32 PM
John & Old Ford
Nov 23, 2012 09:50 AM
jvr-sfbay
1997 - 2003 F150
May 22, 2012 03:38 PM
