Sponsored by: Real Truck
2000 7.3 speedometer problem
Old Apr 5, 2023 | 05:01 PM
Cab swap's Avatar
Cab swap
With the cab swap the speedometer stopped working so i thought it was just the cluster. Then i ran my scanner as i was driving and the speed wasn't rising it just stayed at 0. I have a new speed sensor in the rear. The truck has rear abs. I dont know where to look or what to test to find my problem.
Also it is a manual truck.
Old Apr 5, 2023 | 06:27 PM
2001F350dualwheel's Avatar
2001F350dualwheel
Is the sensor plugged in? Check the integrity of the wire at the connector? Check for voltage at the connector plug pigtail. Also….Make sure it’s all the way in. Sometimes it needs that little last push to snap in
Old Apr 5, 2023 | 07:13 PM
Cab swap's Avatar
Cab swap
Its all the way in the wires look to be in good shape and when should there be power running through the wire when the wheels are turning or is it hot all the time
Old Apr 5, 2023 | 07:27 PM
2001F350dualwheel
Why was the sensor replaced? You could have a bad sensor even if it’s new.
Old Apr 5, 2023 | 07:31 PM
Cab swap's Avatar
Cab swap
Yeah its a brand new sensor i replaced it because i didn't know if that was the issue
Old Apr 5, 2023 | 07:35 PM
2001F350dualwheel
If you did a cab swap I would start checking all the connections. Also look at the transmission if it’s a automatic it’s gonna have a few connectors also on top of the trans body. Make sure those are connected.
mare you using the cluster that worked on the original cab/truck or a new cluster that came with the new cab?
Old Apr 5, 2023 | 07:55 PM
Cab swap's Avatar
Cab swap
All the connections are good thats the first thing i checked. Its the new cluster but its not registering at the obd2 port so that tells be its from the firewall out
Old Apr 5, 2023 | 08:01 PM
2001F350dualwheel
Check the wiring to the sensor. I would also check the big connector at the firewall maybe a pin got bent on install or debris go in there
If everything worked before it should work now. Something got cut not making contact or got disconnected on install
Old Apr 5, 2023 | 08:17 PM
Cab swap's Avatar
Cab swap
Yeah im going to go back through everything but i need to find a way to test the system
Old Apr 5, 2023 | 08:35 PM
2001F350dualwheel
Hey is your ABS light on? And do you have rear abs or 4 wheel abs?
Old Apr 5, 2023 | 08:43 PM
2001F350dualwheel
Your speed sensor is magnetic. This is how you test it
Old Apr 6, 2023 | 06:39 AM
Cab swap's Avatar
Cab swap
No light rear abs
Old Apr 6, 2023 | 05:34 PM
2001F350dualwheel
Originally Posted by Cab swap
No light rear abs
disconnect the sensor. The ABS should pop a code. If it does the sensor works and it’s something else
Old Apr 6, 2023 | 07:06 PM
Cab swap's Avatar
Cab swap
Speed sensor, correct?
Old Apr 7, 2023 | 02:41 AM
2001F350dualwheel
yeah. If the abs pops a code the sensor is working and sending a signal so the problem is elsewhere in the system.
