1965 F100 VIN Decoder
I recently acquired my grandpa's 1965 Ford F100 that he bought new. I learned to drive in it and I would like to get it fixed up so that I can teach my son to drive in it. I have a few years, he's only 4.
I need some help decoding the VIN Number and data plate information. Or at least can someone point me in the right direction so I can figure it out myself. I believe I know what most of it means, but since I have nothing to go off of, I'm going to assume that I know nothing. Which is probably closer to the truth. Thanks in advance. Lance
F10JK677348
WB - 129
Color - F
Model - F100
Body - 281
Trans - F
Axle - 08
Max Gross Weight - 5,000
Net HP - 129
RPM - 4000
D.S.O. - 53
This, if you can slug your way through it, will provide most info.
'67-'72 Ford Trucks MPC - General Info Page 33 - FORDification.com
F10 = F100, 4x2
J = 240 1V in-line six
K = Kansas City Assembly Plant
677348 = 1965 numerical series, April 1965 production
129 = 129 inch wheelbase
F = Color code--I can't find it.
F100 = '64-'71 F100 4x2, 5,000 lbs GVWR, "2 wheel drive-except state of PA"
281
2 = Blue vinyl
81 = Conventional cab
F = Warner T98A OR T18 four speed transmission. (There is some cross over with the top of the transmission and shift pattern, see below for link explaining)
08 = Ford 9" rear axle, 3,300 lbs capacity, 3.50 ratio, non-limited slip
No front axle code, so standard Ford axle.
5000 = 5,000 lbs GVWR
129 4000 = 129 certified net HP @ 4000 RPM
53 = Kansas City District Sales Office
No special order.
T18
https://www.novak-adapt.com/knowledg...anual/t18-t19/
T98
https://www.novak-adapt.com/knowledg...ns/manual/t98/
Decode Your '61-'66 Ford Truck VIN - FORDification.info - The '61-'66 Ford Pickup Resource
F10 = F100, 4x2
F = Color code--I can't find it. see below
281
2 = Blue vinyl
No special order.
T18
T98
I got the F Light Blue code from a 1957/68 loose leaf paper parts catalog that comes in handy. I got it from Pasadena Ford when they closed.
You'd love it, it has pages of accessories that were not in later editions.
Talk about RARE 1964 XL/Sport Black/Black - Ford Truck Enthusiasts Forums (ford-trucks.com)
Reminds me of this post from Michelle and your follow-up response.
rare options. - Ford Truck Enthusiasts Forums (ford-trucks.com)
