68 f100 vin decoding, help please
Old Dec 2, 2004 | 07:55 PM
6268f100's Avatar
6268f100
I'm having trouble finding a credable sourse to decode the vin of my 68' f100. It is a candian truck if this makes a difference. This is what i have:
VIN: F10YCD15109
W.B.: 131
COLOR: J
MODEL: F100
BODY: 5381
TRANS: C 17
AXEL:
MAX LBS: 5000
CERT. NET HP: 179
RPM: 4000
D.S.O.: B68828
Does anyone know what this means or a site that will decode this for me?
Thanks for your help.
Old Dec 2, 2004 | 09:27 PM
The67Beast's Avatar
The67Beast
The book that I use as a reference does not state all of the information that you seek. However, I will tell you what I have. Your VIN number breaks down like this: F10 Y C D 15109 Where the F10 indicates that it is a F-100 @ wheel drive. The "Y" indicates the engine which is a V-8 360 CID with 2v. The "C" is the Assembly Plant, in this case it was put together in Ontario, Canada. As far as the letter "D" goes, my info does not have anything for that. The number 15109 is the Consecutive Number Series where the truck made right before yours would be numbered 15108 and the truck made after yours would be 15110.
On the engine info, my info states that a "Y" engine in that year should have 215 HP with a compression ratio of 8.4:1
As far as the other info is concerned, I do not know. My info may be off as well. I do know that your may contact Ford Motor Company in Detroit and order what they call a "99 History Report". It covers the basics, but will let you know if it had air conditioning, if it is a Ranger or Custom Cab, the rear axle, original colors for interior and exterior. Hope this helps.
Old Dec 3, 2004 | 05:26 PM
aclayton's Avatar
aclayton
68 ford f100 truck VIN #
This is weird...
I just purchased a 68 Ford F100 truck from Altona with the same VIN #.
Please e-mail me back at bclayton@mts.net to confirm this number.
Either you are the previous owner or I have a problem with the VIN on my truck.
Please e-mail me back ASAP
Thanks
Arron
Old Dec 3, 2004 | 06:56 PM
6268f100's Avatar
6268f100
thanks for your help 67Beast
6268f100
Old Dec 3, 2004 | 07:12 PM
1972ford_f-100's Avatar
1972ford_f-100
d is conected to 15109,it says that ur truck was made in april of 68,u have a long box truck,color is Rangoon Red,ur gross vehicle weight is 5000 lbs,a conventional cab,with red interior,3-speed Ford Light Duty tranny,3.25 ratio rear end made by Ford,and ford canida devision west,there u be,if u need to know anything else im here
