Power Steering Question
Old Mar 31, 2023 | 10:38 PM
JimmyRocket's Avatar
JimmyRocket
I have a 2019 Ford F350 Platinum. It has 30,000 miles on it. Recently, I have been hearing a very slight noise from inside the cab in regards to the steering wheel. Maybe a very slight vibration (or feedback) and slight noise when sitting idle and turning the wheel back and fourth. It’s not a sound like when you run low on power steering fluid. The batteries (2) are original, so about 4.5 years old. My question is, could one or both batteries be bad which could cause the adaptive power steering assist to not have enough current to function properly? I haven’t tested the batteries properly yet (I didn’t realize you have to disconnect them and test them separately).
Thank you in advance.
Old Mar 31, 2023 | 10:52 PM
4wd6.7L's Avatar
4wd6.7L
You must mean the Adaptive steering. The electric power steering assist didn't come out until 2020MY. I have read that battery issues have caused faults with the adaptive steering, but they were accompanied by some sort of messages on the display.
I haven't yet read of noises in the steering being related to low batteries, but there have been some who had noise caused by the clock spring.
Old Mar 31, 2023 | 10:58 PM
JimmyRocket
Sorry, you are correct. Adaptive steering. Just looked at my window sticker. I have not seen any messages on my screen yet.
Old Sep 21, 2024 | 12:09 PM
ChiefEng's Avatar
ChiefEng
4wd Low
Adaptive Steering Fault 2020 F250 4X4 crew limited
No weak batteries. This could have been a condition prior to my purchase. I've owned it 3 months. Each time it's started it prompts you that an adaptive steering service is due? Once you press ok it's not displayed again until it's restarted. After the same drill it's the same results. There are no other problems or faults.
Old Sep 21, 2024 | 12:12 PM
4wd6.7L's Avatar
4wd6.7L
What sort of tests have you done on the batteries to determine their health?
h.ubk
Sep 24, 2021 02:38 AM
Krapfl
Aerostar
Jun 27, 2017 05:30 PM
brc777
2009 - 2014 F150
Feb 16, 2014 06:12 PM
mfwhite22
Feb 9, 2009 10:00 AM
montangrunt
Apr 16, 2004 02:45 AM
