I have a few problems with my steering. First, my steering whell has a lot of play in it. What is causing this and how do I fix it. My second question is...whenever I turn the wheel, I get a strong 'whirling' noise. Does anybody have any advise or tips??? I would appreciate any help.
power steering pumps going or just abnormaly loud, mine has done this for the last 30k+ miles on my truck i have learned to deal with it, i might just wait till the pump dies till i fix it? It is a rather common problem with many ford vehicles. i would describe the sound my truck as a whining
power steering pump should be on the Driver's side it I remember correctly. It is very hard to miss. It will be the only thing with a fluid reservoir that has a belt attached to it. It is driven by the serpentine belt on the front of your engine.
If your engine is clean it should have yellow script written on top the the reservoir fill cap.
The play in your steering can be cause by many different factor from bent radius arms, bad bushings, bad tie rods, and so one.
Yep. And essentially, it's a matter of process of elimination. Your truck is 16 years old, and the bushings are probably getting mushy....Good time to start replacing them. Play is usually caused by a worn bushing or connector, such as a tie rod end, that is allowing one or both wheels to move independently of the steering box. You will need to isolate and correct the source of the play before having the truck aligned, or it will not hold the alignment. A tire with a tread separation can also cause the vehicle to wander (sometimes badly).
