Help with transfer case
Old Mar 29, 2023 | 11:40 AM
LONCO's Avatar
LONCO
I’m in the process of converting my 2019 E350 to 4wd. I can’t figure out what transfer case to get. The motor is a V10 and the transmission is a 6R140. I do not have the van in my possession, so I cannot see the rear bolt pattern on the transmission. Did the 6R140 have different bolt patterns? I do not know if it uses the old 6 bolt round pattern or the newer 11 bolt. Also, I am looking for a manual shift transfer case and not an electric.
Old Apr 3, 2023 | 11:03 PM
maples01's Avatar
maples01
It would be an NP273, I believe it to be electronic tho, not sure what you can get thats a manual stick, all depends on the mounting adapter.
Options, look for the trucks with your options.
https://www.blueovaltrucks.com/tech-...ransfer-cases/
Old Apr 4, 2023 | 08:33 AM
LONCO's Avatar
LONCO
That page only covers up to 2005. I think you’re right about the NV273. I’m just trying to figure out which bolt pattern is on the rear of the 6R140 transmission. Is it the round 6 bolt or the newer 10? Bolt.
Old Apr 4, 2023 | 07:05 PM
maples01's Avatar
maples01
Ain't cheap.
https://advanceadapters.com/4503
Old Apr 4, 2023 | 07:23 PM
LONCO's Avatar
LONCO
Dang! I thought (and hoped) the 11? bolt tcase would just bolt up.
https://www.ebay.com/itm/144803039309
Old Apr 4, 2023 | 09:39 PM
maples01's Avatar
maples01
If you have the adapter plate it will, surely you can find a wrecked 4x4 truck with what you need.
MONAVIERONJON
Sep 8, 2017 09:38 AM
Kjreed2087
Engine Swaps
May 19, 2017 06:53 PM
Rulebreaker
Jul 17, 2012 08:44 PM
idaho86f150
Mar 11, 2008 07:50 AM
kmonty20
Offroad & 4x4
Jul 20, 2007 11:53 PM
