Will these E150 capn chairs fit my E350 ??
I located a pair of captains chairs for sale. They came from a handicapped E150 conversion van. They look great, but the mounting system looks so different from my E350 stock bench seats that I want to get some confirmation here before I drive an hour to see them.
Here are the seats in the 150
Here is the mounting system. That big black flat base worries me.
The hole diagram gives me some hope. Do those flat rubber plugs cover bolts screwed into the same floor holes as in my 350?
Some more pics
Some more pics
Those seem to be in the second or third row location, they're aftermarket seats so yes they'll fit almost any E-Series body but you'll need the large flat plate to mount these in another van.
They are not a direct swap for any ford seat, these are installed in an aftermarket conversion. If you're getting both seats and seller will allow you to remove all mounting and the cost is fair a two hour drive isn't a huge waste of time.
I kinda like the mounting scheme--seems very flexible across Ford, Chevy or Dodge if that's any benefit. Add in they're from a manufacturer who puts their name and contact info on the seat components---pretty encouraging to me. Of course cost to buy is a factor and their overall condition as far as how clean and free of rips, tears or broken stitches etc.
Take all that FWIW---I've driven further only to be highly disappointed in what was offered---other times fell into a screaming good deal.
The only problem is removing the bases. I tried to do that with the seats in my 96 conversion van. Accessing the base bolts under the van is pretty much impossible. Some are above the fuel tank, the others above the muffler shielding. And they usually have interference fit threads, so they don't come off easily. I'd rather pull teeth from a wounded Grizzly.
Most of those conversion vans were built to slap together in a hurry----working on most of the interior was always a huge hassle.
Most of the woodwork is fine, but no matter how they put it together, it does work loose over time. I've had to make a few repairs on that. I wish they'd put the same effort they put into mounting the seats in the woodwork.. They're rock solid but the seats are easy to remove with that latching system. Only takes a few minutes to remove the middle captains chairs. Didn't want to butcher up the underside of mine to remove the bases. I put two layers of carpet throw rugs over them to protect my knees when crawlin around in there. Them things HURT !
They're bolted down like I said before, the nuts under the body are impossible to get to, the left side bolts are above the fuel tank. The right sides above the heat shielding for the exhaust. I couldn't get my hands on either side to hold backup on any of them. And I'm 99% certain they either have lock nuts or interference fit threads holding them. If you could reach the nuts, you'll still need someone up inside to work the bolts, if that's what's up there, I don't recall offhand (maybe studs there ? ) If they have studs, good luck trying to work a wrench under there. I see busted knuckles for whoever tries it .
My bases are narrower, the bolts holding them down look like grade 8 or 9 , half inch (3/4" heads) . they're outboard of the base under the carpet. I don't know what type nuts are under the floor, they'd have to be either lock nuts or have an interference thread, like Ford used to use (or still does) on seat bolts. My old 69 Van had interference fit threads on the seat bolts. My front seats (driver and passenger) in this van have 5/16" or 3/8" bolts with regular lock nuts.
The seller pulled those bases off. Here's what's underneath. Those don't look like the standard Ford bolts that hold down the mounting plates for E350 bench seats to me. It looks like the van outfitter cut new holes in the floor and put in some bolts. The Ford setup has welded in nuts in the floorpan, and big Torx bolts that go in from the top.
Or am I mistaken?
Or am I mistaken?
How to remove seat base that is over the gas tank?
Conversion vans are sent out elsewhere, you'd be shocked at some of the stuff they get away with, drywall screws to secure high tops, cut the top with what looks like a can opener, jagged edges left. I have some removable bases from a 96 stored somewhere, need to get rid of them, they bolted down from the top, but have seen those above, wondered how they were secured to the floor, strange a shop would go so far as to drop a gas tank to mount a seat base, tho never surprised.
TheRooster
12-28-2016 08:16 PM
