Push Rod Question
Old Mar 29, 2023 | 07:11 AM
rangerottis's Avatar
rangerottis
Push Rod Question
Hello All! I read often and post seldomly.. My 16 year old son drives an 86 Bronco with a 5.0 efi. Long story short, it blew a head gasket. We've torn it down and kept all of the rocker arms and push rods in order (we're replacing the lifters). What I didn't do is maintain the pushrods in their original orientation. Is there any way to know which way is up and which is down? If we reverse them in reassembly how much excess wear will we be looking at? There is a small diversity in the side of each one near one end that I originally thought was a passage, but it's not. Does this divet help orient them?
Old Mar 29, 2023 | 08:20 AM
FuzzFace2's Avatar
FuzzFace2
I don't know of any way to find out after the fact what is up or down?
It would of been nice to keep trasck of that but to tell the truth I don't think it is that big a deal unlike lifters & rockers / pivots.
I would think if there was any wear marks it would be at the top & rockers.
Dave ----
Old Mar 29, 2023 | 09:53 AM
Olds64's Avatar
Olds64
You could always replace the pushrod too, but I don't think it will be a big deal that the pushrod don't go in the same way they came out. Especially since your replacing the lifters.
Old Mar 29, 2023 | 10:20 AM
rangerottis
That was my general assessment. Thanks for the quick responses!
Old Mar 29, 2023 | 12:25 PM
Rusty_S's Avatar
Rusty_S
Pushrods dont exactly have an up and down, they are the same on both ends.
Only time you run into a up and down situation on pushrods is if you got aftermarket pushrods like I have that uses a standard 180* spherical tip on one end and the other end uses a 210* spherical tip on the other end. The 210* spherical tip is the rocker arm end as it allows for added rocker arm clearance with higher lift cams and prevents the cup in the rocker arm from side loading on the side of the pushrod itself. OE spec pushrods are the same on both ends.
Old Mar 29, 2023 | 08:21 PM
rangerottis
Yes, I realize that the push rods don't have an up or down when initially installed, but I've always been taught to reinstall items with wear surfaces in the same orientation that they were removed. But with the lifters being replaced, I think I'll be OK. Thanks for the reply!
Old Mar 29, 2023 | 08:43 PM
manicmechanic007's Avatar
manicmechanic007
If the head had guide plates you could surely see witness marks where the pushrod was contacting the guide plate
With no guide plates you might still see a witness mark or two
And, of course those marks would be up
Old story from yesteryear. Once I did the same thing and had mine all lined up
An old fart master came around and took and scattered my pushrods all over in the solvent tank
Said I been working on Fords too long
Really It does not matter except sometimes they wear in together
So, just inspect them close for roundness
If they are all nice and round on the ends it will not matter which way you install them
Old Mar 29, 2023 | 09:12 PM
Rusty_S's Avatar
Rusty_S
There really shouldnt be any wear in on these parts that would cause an issue with installing them else where. If there is wear on the pushrod you should replace it as the pushrod tips on OE rods are hardened. Aftermarket can be fully hardened or not, the ones for use with guide plates are all hardened as they contact the guide plates.
Ive seen some pushrods get wear as a result of bad oiling, those I replace as it shouldnt have wear.
Old Mar 30, 2023 | 05:54 PM
packagerjr's Avatar
packagerjr
Tom Monroe’s excellent 335/385 rebuild book suggests to flip them if you’re in that far. So if you didn’t keep track of lifter end/rocker end don’t sweat it.
Eric Kropp
Aug 27, 2014 11:06 AM
huntke
Apr 9, 2012 02:10 PM
Blade79
Maryland Chapter
31
Aug 13, 2010 05:56 PM
76 F250 4X4
Nov 26, 2004 10:23 PM
Rew
Mar 26, 2004 07:40 AM
