Timing job
Old Mar 28, 2023 | 01:27 PM
Anonymous12's Avatar
Anonymous12
Timing job
I have to remove the timing cover, to get a bolt out. I’m doing the timing chain and gears since it’s $30 for the part. When I do it I have someone to help me. I will set it to TDC before I remove the parts and install them at TDC. Do I have to time it at all and remove the SPOUT connector? The thread on it reminded me of that. Or will it be properly timed by removing and installing at TDC?
Old Mar 28, 2023 | 01:58 PM
sandymane's Avatar
sandymane
The way you described, when the motor is not used for TDC, no need for the SPOUT to be removed. You will need to set it to 10degrees BTDC when you finish and the spout will need to be removed. You should use a timing light to do this and they are cheap or you can rent one for free from the Parts stores I think.
Old Mar 28, 2023 | 03:12 PM
Anonymous12
So when I move the gears to top dead center, and remove them. Then install them the same, I have to set it ten degrees before top dead center when everything’s back together?
Old Mar 28, 2023 | 03:14 PM
sandymane's Avatar
sandymane
That's correct. When you remove the SPOUT and set it to 10 degrees that is called BASE TIMING. When you finish setting it and put the Spout back in the PCM takes over the timing job and automatically fluctuates to meet the timing for ALL driving situations.
Old Mar 28, 2023 | 04:05 PM
Anonymous12
How would I set the timing? Do I move the distributor?
Old Mar 28, 2023 | 04:28 PM
sandymane's Avatar
sandymane
It's easier if you watch a video on How to set timing on a 199 ( use your year) Ford F150.
After you watch it then any questions you have will be easier for you and the forum to help.
Old Mar 28, 2023 | 04:29 PM
Anonymous12
All right thanks. I’ll watch a video
Old Mar 29, 2023 | 06:47 AM
manicmechanic007's Avatar
manicmechanic007
You really should not have to retime the engine with a timing light after replacing the timing chain and gears (as long as you set them straight up)
You could do it for GPs and pat yourself on the back, but if the truck goes into a dealer for timing chain and gears replacement...
That is all they will do, They would of course road test their work, and if it pings or ran poor, then the tech might consider using a timing light to set base time
Old Mar 29, 2023 | 11:20 AM
sandymane's Avatar
sandymane
I guess I don't understand since I have never replaced a timing chain. Isn't the timing set at zero after the chain has been properly installed? If so, how do you then get it to 10 degrees BTDC? I am aware of the spout and its purpose. Thanks.
Old Mar 29, 2023 | 11:25 AM
manicmechanic007
The 10 degrees advance is done at the distributor
The timing marks at your cam and crank gears are just dots that you line up with the chain
So, changing the chain and gears does not really affect it unless it was loose as a goose, and someone timed it with the real loose chain
All the ones I have had to re-time over the years... After setting the timing correctly, I see the mark where the factory hit the distributor with a chisel
And the marks line right back up
Old Mar 29, 2023 | 11:49 AM
sandymane's Avatar
sandymane
Gotcha. The OP has many postings of things that he has done so far, without previous experience, or having knowledge of the things that have been done by others. With that in mind, do you feel it is ok to just assume everything is fine after installing the chain and assuming it was done correctly. Thanks again.
Old Mar 29, 2023 | 04:49 PM
manicmechanic007
Not sure what exactly was done to the truck. but the timing and the spout disconnection are critical
The cam timing gears and chain are idiot proof, well almost, I have seen pros get them 180 out
You just make sure if you do time the engine with a light when you are done, that you have it operating temp and the spout out
They call it cookbooking
We all started out knowing very little and cookbook with a service manual is the way you learn
I would assume whatever was done to the truck was done correctly until you have problems
I can post the manual pages for the gears if you need
Old Mar 29, 2023 | 04:54 PM
sandymane's Avatar
sandymane
I was trying to educate myself about the timing. Thanks for your replies.
Old Mar 29, 2023 | 05:04 PM
Anonymous12
If the parts stores loan the tool I have a store 5-10 minutes away. I’ll just take it there and see if they’ll let me check the timing in the parking lot, with or without loaning it. And then I’ll just bring it home if the timings off. I figure it has to be at operating temp anyways so it shouldn’t hurt to drive it 20 minutes at most there and back.
Old Mar 29, 2023 | 05:21 PM
sandymane's Avatar
sandymane
you might want to call them first to mabe save a trip. If they don't, Harbor Freight has good prices on them.
