Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Brake drum removal
Old Mar 26, 2023 | 04:43 PM
BadRadDad's Avatar
BadRadDad
Brake drum removal
I looked and searched and didn’t find a brake drum removal for Rockwell drum brakes 1980’s. Turns out my leaking bleeder valve was a bad wheel cylinder. So I’ve got the cylinder coming Tuesday and wanted to know if I need any special tools to pull the rear drums off.
Old Mar 26, 2023 | 06:38 PM
85e150's Avatar
85e150
You can pull the whole thing--duals, hub and drum if you pull the axle shaft and remove the large nut holding the hub and bearings to the axle housing. But since you are going to swap wheels, you can wait and just pull the hub if you can't get the screws out of the drum etc.
There's a thread with pictures. I'll find it later and post a link.
Old Mar 26, 2023 | 07:44 PM
85e150's Avatar
85e150
Pictures:
https://www.ford-trucks.com/forums/1...l#post20278884
Old Mar 31, 2023 | 06:34 PM
BadRadDad's Avatar
BadRadDad
Do you know what size nut the axle nut is? It shouldn’t be too tight? Channel locks work or do I need a bf socket
Old Mar 31, 2023 | 06:39 PM
85e150's Avatar
85e150
There are several sizes. I think you can get a socket for $30 +/-. Some folks use the hammer and chisel method but you'll not be happy with the results. Channel locks might work but you really need to get the torque spec for installation and use a torque wrench with a socket.
Old Mar 31, 2023 | 09:33 PM
BadRadDad's Avatar
BadRadDad
I don’t mind buying the socket, but what size?
Old Apr 1, 2023 | 12:16 AM
85e150's Avatar
85e150
Rockwell F 106. Maybe someone will know.
Otherwise pull the axle shaft and measure the nut.
Old Apr 7, 2023 | 11:58 PM
BadRadDad's Avatar
BadRadDad
Fyi I found out that it appears from some cross referencing that it may be 3”. I’ll reply after I pull it next week.
so it wasn’t 3” but was 3.5”. The only other thing different from the videos I’ve seen is the retaining washer. It didn’t have ears bent over, but a nipple on the inner nut fit inside the washer
ram1each
Jan 2, 2013 11:41 AM
bloydj
Jun 5, 2012 11:44 AM
MisterCMK
Aug 15, 2007 11:09 AM
I_Love_Cheese
Jun 23, 2007 01:17 PM
Ford_NDN
Sep 8, 2004 02:26 PM
