cruise control issue
Old Mar 24, 2023 | 08:03 PM
rosewoodgang's Avatar
rosewoodgang
5th Gear
I have a 1993 F350 diesel with zf5 speed manual transmission with digital style cruise control <no vaccum> The reason for this question my cruise control will work some times and not at other times. I have the accelerator pedal that is drive by cable only with no electrical connections and no computer is this my issue? I have ohmed all wiring connections from steering colum to cruise control servo including all related switches. I have also replaced clutch interlock switch ws-5993, stop light switch sls-97, master cyclinder switch sw-6350, parking brake switch ds-339, abs wheel speed sensor 970-012, anti lock brake hydrolic unit 12-2024, abs control module and cruise control actuator servo.Checked steering colum connections including wiring,contact ring and cruise switches. Thanks for any information Harvey
Old Mar 24, 2023 | 08:21 PM
Prototypemech's Avatar
Prototypemech
Do you have LED Tail and stop lights?
The cruise control computer is built into the cruise control servo. It reads the speed signal from the programmable speedometer/odometer module (PSOM).
Old Mar 25, 2023 | 08:51 AM
rosewoodgang
5th Gear
no tail lights and stop lights are incandescent style only back up bulbs are LED Thanks for info on [psom] was somewhat sure that no other computer was needed
lED
Old Mar 26, 2023 | 05:49 AM
tjc transport's Avatar
tjc transport
i ain't rite
not sure on the 93, but my pre 91 trucks with vacuum cruise modules would get real wonky when the vacuum pump was going bad.
Old Mar 26, 2023 | 10:53 AM
Prototypemech
I was able to fix my friends 1995 f350 cruise control by cleaning the servo connector and terminals with isopropyl alcohol and a tooth brush.
Old Mar 30, 2023 | 08:49 AM
rosewoodgang
5th Gear
1992 and up cruise control does not use a vaccum port it is completly elestronic controled but thanks for information
Old Mar 30, 2023 | 08:55 AM
rosewoodgang
5th Gear
I have cleaned horn ring connection and applied small amount of white lithium grease along with the connections under steering wheel/horn pad but thanks for information
Andrew Cortese
Mar 16, 2021 11:19 AM
pdsw60
Sep 23, 2020 03:56 AM
whporwil
6.4L Power Stroke Diesel
38
Jan 8, 2014 08:17 PM
GuitarJesus
Jun 26, 2012 08:54 AM
gr8tdragon
Oct 13, 2008 04:55 PM
