Broken 300 head bolt
Old Mar 23, 2023 | 11:53 PM
IsaacCarlson's Avatar
IsaacCarlson
My truck was randomly getting warm and/or puking coolant and it got bad last year so I parked the truck over winter. We pulled the head today and one of the bolts was broken and the gasket was blown in the area near the bolt. The combustion gasses were going into the cooling jacket and blowing the coolant out.
We are going to try removing the broken bolt from the block tomorrow. I am going to try welding a nut to the top and then gently heating the block around the bolt to get it loose. If that doesn't work, it'll have to be drilled/machined out. We'll check the head over tomorrow too.
does anyone know why a head bolt would just break? It looks like it has been broken for a while.
Old Mar 24, 2023 | 02:18 PM
wwhite's Avatar
wwhite
If it has been removed before, reusing stock head bolts depending on type, the can be stretched, then break.
there is a term for bolts that cannot be reused, vs bolts that can.
Over torque can break them as well
Old Mar 24, 2023 | 07:16 PM
IsaacCarlson
I don't know if they were reused or not, but this is not the first head gasket the truck has had. I scraped through 2-3 layers of old gasket.
Old Mar 24, 2023 | 08:18 PM
JJF20's Avatar
JJF20
Torque to yield.
Old Mar 24, 2023 | 11:10 PM
hobohilton's Avatar
hobohilton
Are you soaking the bolt over night with Kroil or similar?
Old Mar 24, 2023 | 11:37 PM
IsaacCarlson
Nope. I tapped the bolt with a hammer to loosen it up and then cleaned the top with a grinder. I turned a nut in the lathe to remove the threads and taper the inside for a better weld. I placed a washer over the bolt and then the nut. I welded it in place with high heat and let cool for several minutes to heat soak the block. I had my son heat the block lightly with a torch while I backed the broken bolt out. It ended up being a textbook removal. The hole is fine and the head should be going back on tomorrow after lapping the valves amd replacing the stem seals. The head is warped .002-.003", which is well within spec for this head.
Old Mar 25, 2023 | 02:44 PM
FuzzFace2's Avatar
FuzzFace2
Originally Posted by JJF20
Torque to yield.
And as far as I know our truck dont use that type head bolts so they can be reused.
But in your case I would replace them all just to be safe.
You said many layers of gaskets?
WTF who did that and was this the head gasket of intake / exh?
Dave ----
Old Mar 25, 2023 | 02:51 PM
IsaacCarlson
We are discussing the head gasket right now. There were at least two distinct layers of gasket residue on the block, plus the stuck pieces from the one I just removed. One was grey and looked like a graphite material, the other had orange in it.
Old Mar 25, 2023 | 03:51 PM
FuzzFace2's Avatar
FuzzFace2
was the person that did that LOL
Wonder what else has not been done right
Good luck
Dave ----
Old Mar 25, 2023 | 03:57 PM
hobohilton's Avatar
hobohilton
How bad is the head warped ?
Old Mar 25, 2023 | 08:41 PM
IsaacCarlson
The head is out .003", which is less than half of the allowable limit.
TooManyToys.
6.4L Power Stroke Diesel
Jun 25, 2021 12:37 PM
UKPR1
Jun 24, 2021 01:31 PM
Scratcher
21
Apr 21, 2011 11:09 AM
hillbillyk
Sep 7, 2008 10:17 PM
Pustman
Aug 11, 2006 12:44 PM
