Help an Old Man
Old Mar 23, 2023 | 05:44 PM
rabbit hutch's Avatar
rabbit hutch
Help an Old Man
I need to remove the **** on the headlight switch on my '90 F150. I have forgotten how to do it and learned a long time ago that using force is too often the wrong answer.
Can anyone help?
Old Mar 23, 2023 | 06:00 PM
Soup bean's Avatar
Soup bean
Old Mar 23, 2023 | 06:12 PM
blazerman07's Avatar
blazerman07
Can anyone help?
I used a dental pick. On the new replacement you will see the spring clip that needs to be pressed.
Old Mar 23, 2023 | 06:38 PM
FuzzFace2's Avatar
FuzzFace2
On the 80 - 86 switch on the back side there is a spring button you need to push.
I find if you push in on the **** a little then push the button and pull on the **** the **** & steam come out as a whole.
You can then get to the nut that holds the switch to the dash.
The wiper **** comes off the way you are shown above.
Dave ----
Old Mar 23, 2023 | 07:19 PM
rabbit hutch
Thank you gentlemen. I'll give that a try tomorrow.
fixitman1310
Nov 4, 2012 09:00 PM
powerstrokedieselfan
Oct 11, 2010 09:11 PM
dhobdey1
Nov 28, 2009 08:39 AM
gary678
Electrical Systems/Wiring
Aug 30, 2006 08:30 PM
HunterFord
1997 - 2003 F150
Apr 19, 2004 08:04 PM
