84 f250 460 electrical problem.
Old Mar 20, 2023 | 08:57 PM
OzarkCU's Avatar
OzarkCU
5th Gear
Truck has to be started by jumping battery any time it is shut off. Once it's started it will run and stay running for however long. But if it's turned off it hast to be boosted to start again.
Once running can disconnect the battery and it will run fine off the alternator.
Just wondering if anyone has any ideas or suggestions
Thanks
Old Mar 20, 2023 | 09:46 PM
hobohilton's Avatar
hobohilton
Has your local auto parts store checked the battery to make sure it is good ?
Old Mar 21, 2023 | 07:25 AM
Franklin2's Avatar
Franklin2
Charge the battery with a plug in charger. Then get a testlight, take the negative battery cable off and lay it on a rag, and hook the lead from the testlight to the end laying on the rag, and touch the testlight probe to the battery negative. Make sure everything is off and the doors are closed. When you touch the probe to the battery negative, if the testlight lights up bright you have a drain in the system.
If you have a drain you can pull fuses till the light goes out. If none of the fuses makes the light go out, you can pull the wires off the alternator and see if the light goes out.
craney89
7.3L / 6.8L V8 Gasoline Engines
Oct 28, 2021 03:45 PM
farmboy87
20
Nov 1, 2015 08:36 PM
Hwyman3
Jul 9, 2013 03:57 PM
SkiRush
Nov 24, 2009 11:51 AM
bigsteve1969
Mar 14, 2009 10:08 PM
