Sponsored by: Real Truck
Which Break Pads / Rotors?
Old Mar 20, 2023 | 04:26 PM
awhit22's Avatar
awhit22
1st Gear
Question Which Break Pads / Rotors?
Hey. I have a 2011 F-350 Super Duty with ~98k miles - First time Super Duty owner. During the summers I regularly tote our 5th Wheel which when loaded is 12-14k lbs depending on the distance/length of trip. I am the 3rd owner, so I don't have all the vehicle history. Prepping for summer travel. Brake pads look like they are getting a little thin both front and back. I am going to replace at least the pads.
Thoughts on replacing both rotors and pads same time or just pads? From the looks of it, these are original rotors, but I don't see any major grooves, or warping.
Which brake pad brands are good for heavy towing and same for rotors? I've looked at PowerStop, who seem more interested in selling rotors and pads vs just pads. Also looked at other brands from major auto parts retailer. Hard to tell which ones last and hold up and are good.
Thanks in advance!
-Adam
Old Mar 20, 2023 | 05:55 PM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
Our F350 is used primarily to pull our 16K 5ver and on my last two trucks I've used Performance Friction (PFC) Carbon Metallic pads on stock rotors. I've tried other brands with no luck, they may be fine for none heavy towing but not heavy they just didn't work out.
Denny
Old Mar 21, 2023 | 08:14 AM
bajaphile's Avatar
bajaphile
Stick with a high quality pad. I think of Motorcraft, Brembo, Hawk, EBC, among many others. Something that will probably cost $50-$100 (you get what you pay for!).
Old Mar 21, 2023 | 10:51 AM
carbonation's Avatar
carbonation
Bosch pads, Raybestos S Groove rotors, and fluid flush with Bosch ES16 fluid.
Old Mar 21, 2023 | 11:06 AM
hobohilton's Avatar
hobohilton
Rotors:
I would see if you can get the OEM rotor's turned rather than buy Chinese.
If you got 98k miles out of OEM then I would replace with OEM.
Some judgement calls there.
Old Mar 22, 2023 | 02:56 PM
Rudiak's Avatar
Rudiak
Motorcraft Severe Duty pads and stock rotors.
Old Mar 23, 2023 | 04:53 PM
WWR's Avatar
WWR
Now's the time to go to '13+ brakes. The front is impractical because you need Super 60 knuckles but the rear is easier and I'd do that.
jstihl
20
Apr 14, 2017 08:27 PM
Coupleofords
2009 - 2014 F150
Feb 21, 2017 06:17 AM
Macmathews
19
Jun 13, 2016 11:21 PM
1950gmcelc
Jun 15, 2014 10:18 AM
BOA66
Mar 3, 2006 12:59 AM
