rotors/pads?
I'm a fan of the ART (Applied Rotor Technology) rotors. They sell pads too. Link here:
http://member.newsguy.com/~nutech/frames.html
They are more expensive than standard rotors, but due to them being cryogenicaly treated, they are suppose to resist warping a lot better than standard rotors, which seems to be a common problem on these big trucks.
I'd skip the ceramic pads - I have read, (and was told at the parts store,) that you don't want to use ceramic pads on a heavy duty pick-up...
A popular choice around here is the Powerslot rotors, along with Hawk brake pads - do a seach and you'll get some reading. This option is probably what I will go with in the near future - if I towed a lot, I might consider the ART's - but they are kinda pricey!
Ceramic pads are not fade resistant. I think the Bendix site had a disclaimer about towing and ceramic pads.
I wanted ceramic for the low dust, but I tow a 5th wheel and gooseneck and didn't want to be without brakes just so my wheels stay cleaner.
If I didn't tow anything, I'd probably go with the ceramics. I have the Hawk Performance LTS pads. They do a good job and produce less dust than the NAPA heavy duty ones I had before.
A lot of people are very happy with Performance Frictions or other brands of carbon metallic. I did a similar post a while back, and most people liked the performance frictions. I decided to try something different to see what they were like.
Correction. From bosch website.
Q. How are ceramic brake pads different from semi-metallic brake pads?
A. Ceramic brake pads incorporate a formula that includes ceramic materials and utilizes less metal (approximately 15% metal content by weight). Ceramic brake pads combine exceptional braking power with very quiet and low-dust braking. However, it is not recommended to use ceramic brake pads for towing applications. Semi-Metallic brake pads incorporate a formula that utilizes approximately 40% or more metal content by weight. Semi-Met brake pads offer premium braking power and work particularly well for towing applications.
Not much detail, but the lack of fade resistance is what I've heard.
I would stay away from any of the drilled rotors. They will crack and you'll have to replace them all over again. I have talked to a guy at www.horsepowerupgrades.com and they suggest the Powerslot Rotors and Hawk pads. You could get the Cryo rotors, where they freeze them, which is supposed to make them even better.
