460 engine mounts
Old Mar 19, 2023 | 05:42 PM
5speed65's Avatar
5speed65
460 engine mounts
Hi all
i am putting back in the 460 and the previous L&L mounts ripped so I thought I would use these using the l&l perches
and I cannot for the life of me get the engine to line up the throttle is hitting the bellhosing bolt and they are not settling in the stands
am I pretty much forced to use l&l rubber mounts or is there something I’m missing ?
Old Mar 19, 2023 | 08:30 PM
ranger140892's Avatar
ranger140892
Grumpy goat
Check out 460 EFI Guys.
https://460efiguys.com/bullet-proof-motor-mounts/
Old Mar 20, 2023 | 04:54 AM
Lds79ford's Avatar
Lds79ford
Senior Master
I used the efi guys one with no issue, does the Jeff’s bronco one still only have a half welded stud that goes through the tower? That’s why I returned and went with efi guys
Old Mar 20, 2023 | 09:04 AM
mark a.'s Avatar
mark a.
If you throw the L&L stands in the junk where they belong and get a factory set I'll bet it drops right in.
Old Mar 20, 2023 | 10:44 AM
5speed65's Avatar
5speed65
The swap was done in 94 by the previous owner and I do not have the original perches so I think my only options are to replace the mounts each time the rip :/
Old Mar 20, 2023 | 07:44 PM
broktruk's Avatar
broktruk
4wd. There’s no oem style available other than the LNL rubber. Unfortunately, I have to do the old 390 car mounts swap side to side in order to get my 460 to sit low enough.
H311RA151N
29
Nov 19, 2017 02:19 PM
psquare7575
Jul 31, 2011 09:56 PM
tom1979
17
Jul 10, 2009 05:52 PM
FordTrucksKickGM
Mar 22, 2008 03:32 PM
