I just installed an Edge CTS3 in my 2022 6.7.
It will show 16 gauges and after choosing the ones I wanted, I've still got 2 open spots. Figure the EGT values would be helpful, but there are 4 EGT's listed (EGT1 to EGT4). Would someone let me know the access points of the 4 values and which are the more indicative of the engine status.
FERdter (FERoadster)
Originally Posted by Painted Horse
He said he is deleted. So none of those exist any longer.
The 4 factory sensors are gone.
I believe Ford added the pre-turbo egt probe in 15. I know my 16 has one. Look at the drivers side up-pipe, it is easily visible. I actually went round and round with Edge on this. When I first installed my CTS3 it found 5 egt sensors. 1 being the pre-turbo and it displayed the temp. After one of the updates, that pid disappeared along with another one. They tried several updates for me, trying to get it back to no avail, they say it was caused by an ecm flash, I dont agree because it showed for some time after the flash. I was however successful in getting them to add and display LPFP (low pressure fuel pump). I was irritated by the whole situation but will say their tech support and "engineers" tried multiple revisions for me and finally ended up making me a deal on an EAS sensor to get egt back. Kind of long winded answer but hopefully it helps.
Edit: Forgot to add that it was labeled EGT and then had EGT1-EGT4.
