Distributor pickup
Old Feb 27, 2022 | 08:12 PM
Prionus's Avatar
Prionus
Distributor pickup
Is the distributor pickup within the housing replaceable? Does this part go bad? My timing has moved slightly again and I’m wondering if this is where things are loose.
Old Feb 28, 2022 | 03:15 AM
FuzzFace2's Avatar
FuzzFace2
Yes
Yes
No
You did not post what year, motor and ignition system DSII with vacuum hose or TFI no vacuum hose so it is hard it say why it is changing. By how much dose it change?
Dave ----
Old Feb 28, 2022 | 07:20 AM
Max Capacity's Avatar
Max Capacity
I recommend replacing the distributor with a rebuilt one. I learned that the hard way after spending lots of money chasing issues and finally replaced the dizzy. A rebuilt dizzy is not that much money.
How old is your distributor ?
Old Feb 28, 2022 | 12:52 PM
dustyroad's Avatar
dustyroad
check your timing chain if you've never replaced it.
Old Feb 28, 2022 | 01:13 PM
pearljam724's Avatar
pearljam724
Check that the distributor is tightened down also.
Old Feb 28, 2022 | 05:12 PM
Prionus's Avatar
Prionus
Dang. 1982 F350 351W. Does it matter the source? Would Napa be a good source? Thanks for the suggestion.
Old Feb 28, 2022 | 05:34 PM
pearljam724
https://www.ebay.com/itm/Ignition-Di...-127632-2357-0
Old Feb 28, 2022 | 06:29 PM
GLR's Avatar
GLR
I think the Ebay listing is for a 351M
www.rockauto.com is another good source.
And, yes, NAPA would be a good source also.
Old Mar 1, 2022 | 07:45 AM
Max Capacity
Yes, NAPA or your local auto parts store would be good. My local NAPA store still has the same guys working there as when I first stopped in some 12 years ago. When I have an issue, there is someone to talk too about it. You don't get that from EBAY or on line somewhere across the country.
Your also supporting a local business and your neighbors that work there.
Old Mar 1, 2022 | 10:42 AM
kr98664's Avatar
kr98664
My experience here:
https://www.ford-trucks.com/forums/1...tator-gap.html
Some good info from the '73-'79 forum:
https://www.ford-trucks.com/forums/1...stributor.html
For your situation, with the ignition timing appearing to have shifted, there are a few things to check:
Does the engine run differently? That might indicated a loose timing chain that has jumped a tooth or two. It could also indicate a sheared roll pin on the distributor drive gear.
If the engine runs the same, make sure the outer portion of the crankshaft pulley has not slipped. If it did, this would change the indication with the timing light, but the engine performance would be unchanged. To check, remove the spark plugs and put #1 piston at TDC. Use a soda straw or something similar through the spark plug hole. Do NOT use anything rigid that could snap off, such as a screwdriver. I do not care to discuss how I know this. With the piston at TDC, look at your timing marks. If not showing TDC, the pulley has slipped.
Old Mar 1, 2022 | 11:25 AM
Prionus's Avatar
Prionus
Thanks everyone. The timing is changing about 5-10 degrees. This is the second time in a month. I really don’t think it’s the timing chain because I can get it run good with a little turn of the distrubutor. The crank pulley is not slipping.
Old Mar 1, 2022 | 12:08 PM
FuzzFace2's Avatar
FuzzFace2
Thats a lot to move to get timing back where it should be.
If you have the timing set now, mark the dist. base and some place close by to see if it is the dist. turning or something else.
Dave ----
Old Mar 1, 2022 | 12:17 PM
dustyroad's Avatar
dustyroad
The only way to ensure it isn't the timing chain is to watch the rotor while turning the crank.
Than you will know absolutely and can rule it out for good. Absolutely turning the dizzy is going to put it back in time until it happens again.
I'm not discounting others opinions they could be exactly spot on, but imnsho you don't know until you confirm. Parts cannon or rule it out step by step?
Old Mar 1, 2022 | 12:29 PM
GLR's Avatar
GLR
Don't know if Ford was using a nylon teeth cam gear in 82. But, that could be a problem. I know my 86 F250 351W has a double tooth steel gear set, stock.
Old Mar 1, 2022 | 02:22 PM
dustyroad's Avatar
dustyroad
I thought they used nylon all thru the 80's? I've attempted to find info on when they stopped and went all metal but no luck on that so far.
Would be nice to know than I won't tell anyone to replace their nylon setup anymore.
did you buy your 86 new or used?
