1999 V10 Triton coolant flushed and overheated
If this is not the correct place my apologies.
This is a 1999 coachmen Mirada RV.
I decided to flush my cooling system with a chemical flush.
Drained the system added the coolant, ran the engine.. 10 minutes in the temperature gauge was maxed out..I immediately realized the motor was not getting any coolant. I squeezed the upper large radiator hose and felt a gush of coolant flow. The temp gauge was reading normal again..didn't think much of it.
After the third flush I realized there was oil in my coolant. I checked the dipstick and it was indeed low there is now oil in my coolant.
I decided to try and trouble shoot the oil cooler by removing it from the system and checking for oil coming from it. No oil. I'm not sure if there is a certain temperature that the oil needs to reach for it to come out of that is where my problem is..
I also realize the chances are good that I have a blown head gasket or worse cracked or warped heads. I'm hoping someone can give me any advice or information..maybe there is another option.
Thanks
Thanks
There was probably air trapped in the cooling system that needed to be vented out before starting.
That may have created a "hot spot" somewhere in the cooling system.
Best to get a coolant pressure test kit and see if the system is losing pressure back through a head gasket.
Auto parts stores rent those kits.
Is there any other place besides the head gasket or oil cooler that would allow oil into the cooling system?
i removed it so i could achieve the flushes faster and not have to wait for the engine to reach 190. the vehicle was not going to be moved, just stationary. tomorrow i am going to put the thermostat back in , drive it 20 mins down the road while still bypassing the oil cooler and see if any oil in my cooling system.
fingers crossed this is my home and I have a new job lined up for april 1st.
ok i decided to just buy the new oil cooler from autozone for a premium to ease my worried mind. threw it in. put back the thermostat, filled the radiator to the top by removing the thermostat hose. made sure the engine was full took it for a 30 min ride. drained the coolant, it was clear. thank god!!
turns out the chemical flush must have made the oil cooler fail. never again with the chemical flush.
akuhr93'f150
1997 - 2003 F150
11-26-2013 02:17 PM
blowin_smoke_1977
05-23-2012 10:55 PM
ghanson
1999 to 2016 Super Duty
08-13-2011 08:55 AM
