77 ford truck starting problem
Old Nov 16, 2003 | 12:50 PM
dave303's Avatar
dave303
ok im not getting no spark out the coil and ive put two new ones in it already and still not getting spark out the coil...heres what ive replaced so far a new ignition swicth' a new cylanoid, 2 new coils , ive went to replace the electronic module and they tested it and said it was fine..please if anyone can help please do thanks dave.
Old Nov 16, 2003 | 03:12 PM
cpnhgnjnky's Avatar
cpnhgnjnky
Since you are new its cool, but to get a response go to the appropriate forum and post there.
CJ
Old Nov 16, 2003 | 03:15 PM
Torque1st's Avatar
Torque1st
Posting Legend
Moved to electrical systems
Old Nov 16, 2003 | 03:22 PM
drunkenmonk's Avatar
drunkenmonk
have you checked the distributor
Old Nov 18, 2003 | 09:22 PM
mvassek's Avatar
mvassek
Replace the ignition module. I just spent 3 weeks trying to get a 1975 f-100 running . I had the Module tested, it tested good so I ended up replacing the coil, the magnetic pickup in the distributor, the starter solenoid, plugs, wires, and then tested them with a meter over and over to make sure they were doing what they were supposed to. I finally broke down and just spent the $16.00 on the module. I hooked it up and the truck started right up.
I drove it for 30 minutes and then it caught on fire due to other problems. It is now back up and running if replacing the module doesn't do it. Let me know here and I will go over all of the other stuff zi checked to help ensure you aren't overlooking anytyhing, but the new module should do the trick Good luck.
Old Nov 19, 2003 | 12:31 PM
Franklin2's Avatar
Franklin2
Make sure you have voltage on the + of the coil with the key on.
Another guy also had a problem a few days ago in this forum, and after replacing everything, he found the black ground wire coming from the pickup in the dist was not connected firmly under the screw.
Old Nov 26, 2003 | 11:16 PM
mvassek's Avatar
mvassek
Franklin2
That was me, I put it under the screw to firmly and broke the screw off with about only one thread into the hole. That little screw had 6 guys from work me and my father-in-law all racking our brains. The worst part while I was standing with my head under the hood and grumbling my wife asked "Are you sure all of the grounds are good" I said "yes I have checked the grounds they are all good I have checked everything 100 times already and have no darn clue" She sure had fun saying "I told you to check all of the grounds if you would have listended to dumb ole me you would have been driving this thing 4 days ago. Knucklehead" I think she loves me anyone else would have probably called me worse than knucklehaed.
tjs_79ford
Sep 20, 2009 11:30 AM
RangerBlues
Electrical Systems/Wiring
Dec 14, 2006 10:15 AM
Okcdiscgolfer
1978 - 1996 Big Bronco
13
Oct 8, 2006 09:19 PM
treemonkey
Feb 20, 2005 12:32 PM
Dave874.9L
Oct 30, 2004 01:29 PM
