stuck distributor
Old Nov 16, 2003 | 12:22 PM
5131's Avatar
5131
stuck distributor
Anybody happen to know of any tricks to get a stuck distributor out of a 351m ? I intended to replace the cam and lifters but now this also includes removing a broken bolt in the head from the exhaust manifold and I would rather not have this project continue to grow so I am looking for non-violent means of removing the distributor.
Thank you for your time :5131
Old Nov 16, 2003 | 12:51 PM
ncl's Avatar
ncl
Try using some PB blaster in the yellow cap or Aero kroil these are the best penetrants available spray it around the base liberally and tap on the shaft where it goes down into block. Then it should come out.
Old Nov 16, 2003 | 02:17 PM
Torque1st's Avatar
Torque1st
Posting Legend
Moved to proper engine forum. You may find the information you are looking for in this forum using the search function. This is a common problem.
Old Nov 16, 2003 | 04:12 PM
5131's Avatar
5131
Sorry about the screwup on my part ,I need to pay more attention I guess
Old Nov 16, 2003 | 06:43 PM
danlee's Avatar
danlee
I used a small curved nail puller. I tapped it gently between the dist. and the block. Then applied some pressure. If you can just get it in there, then apply some penetrant it will help.
Old Nov 17, 2003 | 01:22 AM
jdon88's Avatar
jdon88
If the engine is out of the truck rotate it upside down, remove oil pan and spray some PB Blaster to soak it from the bottom. It worked for me.
Bigbruce
Jul 6, 2013 07:27 AM
torque head
1978 - 1996 Big Bronco
May 28, 2010 10:51 PM
hba5131
1997 - 2003 F150
Oct 25, 2001 01:46 AM
