Thread on how to do full fluid change?
Old Mar 8, 2023 | 05:38 PM
Maillemaker's Avatar
Maillemaker
Somewhere around here was a thread on how to do a full transmission fluid change. Anyone know where it is?
Steve
Old Mar 8, 2023 | 06:24 PM
Maillemaker
Found it:
https://www.ford-trucks.com/articles...-transmission/
Old Mar 9, 2023 | 04:59 AM
JWA's Avatar
JWA
This procedure can be very transmission type dependent--should be plenty of helpful and more specific information in the transmission sub-forum. I've used Mark K's general procedure on two 4R70W's and one 4R75E with great success.
Old Mar 9, 2023 | 05:56 AM
manicmechanic007's Avatar
manicmechanic007
5 gallon bucket of new clean fluid and one empty one
Crack the tranc cooler lines and feed the return into a empty bucket
Put the other end with a piece of hose in your clean bucket of new fluid
That will be the easiest way to do it yourself
But, why would you want to do that?
The recommended transmission service replaces roughly a third of the trans fluid every 30k miles and that is sufficient
We used to sell flushes using the BG equipment.
Leave that alone
I used to flush power steering systems back in the early eighties when the C2 pumps came out and whined so bad
Basically you stick the return in a bucket and feed new fluid in the other end of the hose
A running engine will suck up trans fluid faster that 3 guys can feed it (hence the flush machine)
The flush machines clean your fluid, and you get no new fluid, except to top it off when done
So, the bucket method is it, if you really want to do that
Old Mar 9, 2023 | 06:51 AM
Maillemaker
I have recently purchased a used vehicle with unknown service history and 102,000 miles.
Old Mar 9, 2023 | 08:10 AM
manicmechanic007
Better have the fluid looked at
We used to say on ones that have never been serviced
"Let's service it today and put a new trans in it next week"
Meaning if the fluid is burnt and you replace even a third of the trans fluid, the vehicle will not move afterward
Happens very few and far between, and the synthetic mercon is hard to beat up (lasts 100k no problem unless you tow)
So, just smell the fluid and put some on a white paper plate, (inspect closely)
Good luck
If you can't stand the smell, it may be too late
Old Mar 9, 2023 | 08:13 AM
manicmechanic007
102k it should be just fine to service
You are just a little late
Find a pan with a drain plug and replace it when it is off
Re-use the re-useable gasket
Old Mar 9, 2023 | 08:28 AM
Maillemaker
I have heard the thing before that if you replace the fluid you can break the transmission, but I suspect that if that is the case the transmission is already broken you just didn't realize it yet. In other words, clean transmission fluid isn't going to damage a transmission. Now it may well be that the increased lubricity of clean fluid causes changes in slippage or whatever, but the fluid didn't break anything that wasn't already broken.
But I just checked the fluid, and it looks reasonably pink and doesn't smell bad.
Old Mar 9, 2023 | 08:38 AM
manicmechanic007
What happens is, the clutch packs go away with the burnt fluid, rendering the transmission useless
So, the old, burnt fluid contains the grit (clutch pack friction material) that is making the trans operate (move)
You replace that with new fluid and it's game over
Old Mar 9, 2023 | 10:00 AM
econo93's Avatar
econo93
Over the past 15 years I've bought two older vans that had 115K-125k on them with unknown maintenance histories. What I've done is to use a fluid extractor such as a Mityvac to remove 4 quarts of trans fluid at a time, repeating every 10,000 miles.
I also installed auxiliary trans coolers and inline magnetic filters.
Never had a problem with the trans in the old '91 van and it had 175k on it when it finally met the crusher. My present '93 had 112k on it when I bought it 5 years ago and now has 153k on it. That's at the point when a lot of trannies die, so we'll see if my luck holds.
Old Mar 10, 2023 | 08:16 PM
My4Fordtrucks's Avatar
My4Fordtrucks
I believe Mark Kovalsky would disagree with you.
Old Mar 10, 2023 | 09:46 PM
manicmechanic007
I doubt it, you should ask him
That is exactly how they fail
Old Mar 11, 2023 | 09:19 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The problem with this method is that you don't know how a transmission works. There is no suction in the cooler line, will the fluid just run into the line because you want it to? You need to get the new fluid into the pan for the filter to pick it up. Your method will not work at all.
That's just an old wive's tale, but with just a hint of truth.
Quite often people ignore the trans until something goes wrong. Then they change the fluid and the trans fails. It was already failed when it started to act up, the new fluid didn't repair it, but it also did not cause the failure. It would have also failed if the fluid wasn't changed.
I agree with this.
That's not at all correct. Not even close.
Nope. I do not agree. I explained above what is really happening.
Old Mar 12, 2023 | 04:21 AM
manicmechanic007
Quack
That is why you were an engineer
Youn would never make it as a line tech
That is why you need a flush machine or just add your fluid to the dipstick tube
You want to argue about how they fail again with burnt fluid?
Your engineering degree and 50 cents will buy a cup off coffee
Old Mar 12, 2023 | 05:18 AM
JWA's Avatar
JWA
Quack
Same for your claims of being some sort of gold certified Ford mechanic dude. In my years here on FTE I've seen Mark K's advice help many many people with clear concise information rather than some back alley "advice" that is not helpful at all.
