Ota update
Old Mar 9, 2023 | 04:21 PM
Texmudder's Avatar
Texmudder
They come over the cellular network. There are settings in your Sync4 system that tell it how often to check for updates.
Old Mar 9, 2023 | 10:22 PM
Lariat Driver's Avatar
Lariat Driver
Veteran: Navy
I think my truck just pulled down 3.5.4 in the last day or so. Sync 4. Now everytime I start the truck it goes to the Audio screen even though it was on Nav when I shut the truck off. I looked through the setting today and didn't see any place to set a default startup screen.
Old Mar 9, 2023 | 11:55 PM
Ees73's Avatar
Ees73
Ya full of bugs how is your nave search does it have the Kip words in it?
Old Mar 10, 2023 | 09:52 PM
Lariat Driver
Veteran: Navy
Nav search seems to be functioning properly with no additional letters or characters being displayed. But it still is going to the Audio screen every restart.
On the plus side, it now looks like the FordPass App is showing the DEF status in the app for a Sync 4 system. Last year I did a small survey of FTE members who could see their DEF status in the app and only folks with Sync 3 saw it then. Nobody with Sync 4 could see it in the app.
Old Mar 11, 2023 | 10:19 AM
Buckeye-SD's Avatar
Buckeye-SD
Interesting. My Sync4 reported DEF to Fordpass properly since I picked up the truck. Was on 3.5.1, 3.5.2 and now 3.5.3. I'm trying to force 3.5.4 now.
Old Mar 11, 2023 | 10:21 AM
schrod's Avatar
schrod
Originally Posted by Buckeye-SD
Does you truck have a name? I SUGGEST KIP...
I went and forced an update earlier and got 3.5.3. I did it again hoping to get 3.5.4 for full screen CarPlay. Now I'm worried I'll get the KIP bug....
Just how does one "force" an update?
Old Mar 11, 2023 | 11:46 AM
Ees73's Avatar
Ees73
I had a 2017 I believe that always switched to tuner they had to replace actual radio to fix. After I fought with them for many visits lol
Old Mar 11, 2023 | 01:10 PM
Ees73's Avatar
Ees73
I called into sync help and they said there are known issues they're working on to release a fix she didn't know for sure what but hopefully that's all it is
Old Mar 11, 2023 | 01:50 PM
Buckeye-SD's Avatar
Buckeye-SD
. I did it when I first got my truck and got version 3.5.2. When I saw this thread I did it again and it pulled down 3.5.3. I'm trying again for 3.5.4 for full screen CarPlay. note:, it seems to take 2-3 days for the process to complete. I'm getting the system update icon, but pressing it has no info.
Old Mar 24, 2023 | 02:34 PM
Qvan666's Avatar
Qvan666
Originally Posted by vitacura
My truck has received two OTA updates in the last month. One added Alexa and yesterdays (3.5.4) mentioned the dual phone/screen resizing and updated owner's manual. Navigating seems fine.
Other than the Alexa symbol the only other change I've noticed is when I activate the 360 cameras I now see two trucks on the screen whereas before I only remember the standard big one.
I have the same thing. I put it in reverse and had my wife walk around and the little truck did nothing when the proximity sensors went off so I am clueless as to why it is there. OTOH, if in the 360 mode and you open a door you can get another truck. I think it is some software engineer just trying stuff out.
bob
Old Mar 24, 2023 | 05:12 PM
schrod's Avatar
schrod
This video describes the process. I did it when I first got my truck and got version 3.5.2. When I saw this thread I did it again and it pulled down 3.5.3. I'm trying again for 3.5.4 for full screen CarPlay. note:, it seems to take 2-3 days for the process to complete. I'm getting the system update icon, but pressing it has no info.
Tried doing this. Does not work for me.
Old Mar 25, 2023 | 04:57 PM
Buckeye-SD's Avatar
Buckeye-SD
It is definitely hit or miss. I still haven't had luck with 3.5.4 downloading. Keep trying....
Old Mar 29, 2023 | 04:30 PM
  #28
Rob38jr's Avatar
Rob38jr
I renewed the Navigation App yesterday (expired last month) and later in the day i had the long awaited Carplay full screen update and my Navigation was again activated. Problem is Ingot the KIP glitch or bug. It’s essentially worthless to me as I’m not gonna try to use it with that sh^t going on. Anyway, those of ypu that got that bug, have you had it corrected or told what the fix is?
Old Mar 29, 2023 | 04:33 PM
  #29
Ees73's Avatar
Ees73
You have to put you Nav search while in motion setting in apim back to how it was with forscan there is no working code for search in motion since update. I put mine back and all normal now again
Old Mar 30, 2023 | 06:38 PM
  #30
Rob38jr's Avatar
Rob38jr
Question for you guys with more experience with Forscan than I. I downloaded Forscan last fall and made the common changes folks are making. I dont recall if it was a 2 month version, 1 year, etc. free trial and need to go back now and reverse the Nav in motion change due to the KIP bug. Before connecting to the truck is there a way to look at Forscan when launched and see if my subscription is still valid? If not how do I renew extended Forscan? Which as I recall I need to make changes.
