351m water pump
Old Mar 6, 2023 | 10:59 PM
black & blue 78/9's Avatar
black & blue 78/9
351m water pump
With today's crappy parts from mcparts stores, am I crazy to think about rebuilding my water pump? What goes bad on the water pump to make it sloooowly weep out the weep hole? Has anyone on here ever rebuilt their pump? Where would I find these parts? What are the parts called?
Thanks for any help. Chris
Old Mar 6, 2023 | 11:23 PM
tbear853's Avatar
tbear853
I always just went to the parts store and bought one. I expect it takes a press at least to reassemble after you find a way to pull it apart to put in seals ... that I've never known to be readily available to a DIYer.
Old Mar 7, 2023 | 07:44 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
I believe internal seals go bad and then the sadness starts with the weep hole drip. X2 not sure it you can even get the stand alone parts to rebuild it. Good luck.
Old Mar 7, 2023 | 09:20 AM
labdad32's Avatar
labdad32
Something else to consider will be the condition of the cover plate once you remove the pump. Mine was worn to a point it had to be replaced.
Old Mar 7, 2023 | 11:25 AM
Red Mercury's Avatar
Red Mercury
As others have stated the seal usually starts to leak sometimes followed or caused by worn bearings.
Rebuild kits are available for some agriculture applications and I also believe the heavy truck industry. I did get a small farm tractor pump kit for a farm tractor years ago when a new pump itself was not available.
I quick google brought me to this site Dead Nuts On, unfortunately I didn't see anything for 351M/400 applications. The other Ford applications shown may use the same parts.
The world seems to have accepted that water pumps are a replacement item and are not rebuildable. I have started keeping the original Ford water pumps, alternators, & starters a few years ago instead of returning them as cores. I much prefer the quality of the Ford parts. I haven't had to rebuild a water pump yet, so I will be watching this thread to see what the responses are.
Red
Old Mar 7, 2023 | 12:25 PM
5851a's Avatar
5851a
There are people that will restore the pumps, check ads in Hemmings. Those guys restoring Mustangs don't give up on date coded parts. Only downside is sending in yours. Get a crap replacement and send your old one to a rebuilder while you wait for crap one to let go.
Old Mar 7, 2023 | 02:25 PM
Mark8man's Avatar
Mark8man
I've found water pumps to be one of the better aftermarket parts as long as you pay up a little buy a higher quality unit. I'd just buy one and move on.
Master cylinders, starters, alternators are a different story.
waltharper
Oregon Chapter
Dec 3, 2014 12:53 AM
skibender2
Jul 11, 2005 07:00 AM
Gouber
Apr 14, 2005 10:16 PM
Bessy'sBrokeAgain
Aug 3, 2004 02:34 AM
BEAVER
Sep 23, 2001 02:17 PM
