Sponsored by: Real Truck
2000 f250
Old Mar 6, 2023 | 07:08 PM
chris3723's Avatar
chris3723
1st Gear
2000 f250
hi everyone i have a 2000 f250 super duty xlt 4x4 my will not work turn switch on and nothing no 4x4 light so i changed switch still nothing any suggestions?
Old Mar 7, 2023 | 08:38 AM
PJWhelan's Avatar
PJWhelan
Sorry, if you need help with an issue you're going to have to be a bit more clear. The sentence was a mis-mosh and I'm sure the group was mystified as well.
Old Mar 7, 2023 | 08:39 AM
S-squatch's Avatar
S-squatch
Check fuse 17, and the transfer case shift relays for operation and power/ground/control
Old Mar 7, 2023 | 09:16 AM
nydiver's Avatar
nydiver
Manual transfer case, never wonder again. Pull the lever its in, push it and its out. Beyond that you can check the relays, the connector on the shift motor for loose or corrosion, trace back wiring to be sure isn't broken under the truck, then pull the shift motor and see if its moving with the switch or do you need to replace that.
RevRick 611
Jan 17, 2022 10:57 AM
tree_7474
Jan 15, 2011 05:08 PM
Bumpkis
Dec 27, 2009 02:03 PM
Daviddc114
Jul 10, 2007 11:48 AM
Johnny_B_Bummin
Offroad & 4x4
Jan 5, 2004 10:28 PM
