E4OD proper shift pattern?
Old Mar 6, 2023 | 08:17 AM
DanielT28's Avatar
DanielT28
Hey guys. Another question. What is the proper shift pattern for our trucks with the E4OD?
I feel like my truck drives just fine. Until I have to get on the throttle pulling out in traffic or from a stop if I get on it. Seems like 1-2 it holds rpm’s and shifts nice. But then 3&4th gear the rpm’s go low high low or something weird. I’ll try to get a video of it. Anyways I wish it would hold gears at rpm’s longer. Would something like the banks trans command help this? Maybe a Hydra? Thanks
Old Mar 6, 2023 | 08:30 AM
z31freakify's Avatar
z31freakify
Maybe the TC not locking up? Does it to like a slip between shifts? (RPM rise while it shifts) could be just a tuning issue.
Old Mar 6, 2023 | 08:50 AM
DanielT28's Avatar
DanielT28
it doesn’t slip I don’t think. It just shifts too early or something. Or locks unlocks
Old Mar 6, 2023 | 08:58 AM
z31freakify
Reset the TPS and see how it does.
key on, pedal pressed gently to WOT in less than 5 seconds release pedal close key, repeat 2 more times.
Old Mar 6, 2023 | 11:07 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
It depends 100% on what your calibration code is.
Some calibrations shift earlier, some apply the torque converter clutch at lower accelerator pedal positions than others in 2nd gear, some don't apply the TCC in 3rd gear unless the accelerator is pressed more than 50% and apply it immediately after the 3-4 shift.
Some release the torque converter clutch when the accelerator pedal is released and some leave it applied until the brake pedal is depressed (or 12/30 seconds after the accelerator pedal is released).
There is no one simple answer.
Old Mar 23, 2023 | 09:04 AM
DanielT28's Avatar
DanielT28
Finally got a video of what the truck is doing while accelerating. Pretty annoying that it won’t hold RPM longer. But maybe this is correct? You guys tell me. Just reset the TPS after this drive. Haven’t driven it yet. Will report back after a while
Old Mar 23, 2023 | 11:57 AM
Briansshop's Avatar
Briansshop
Looks like that could just be TCC apply. I never like the big rpm drop between locked/unlocked TC. Even more annoying with an aftermarket higher stall TC.
Old Mar 23, 2023 | 12:06 PM
FinnishStroker's Avatar
FinnishStroker
We want TC to lock to bring the rpms down to the torque range.
Is it doing something weird before it actually locks TC?
You can adjust the shifting as you want it with Hydra chip and custom tuning.
Old Mar 23, 2023 | 12:36 PM
DanielT28's Avatar
DanielT28
I guess I just want it to hold the gear longer because when it shifts up it causes the engine to lug building EGT
Old Mar 23, 2023 | 05:09 PM
FinnishStroker
Still have the OEM cobra style downpipe?
Ditching it and soot trap(If you have it),helps exhaust flow a bit.
TP38 1.15 AR exhaust housing makes the EGT worse at lower rpms.But it shines in the upper end.
Old Mar 23, 2023 | 05:18 PM
DanielT28's Avatar
DanielT28
no i have the down pipe upgraded
Darrel B. Nicklaus
Jul 20, 2018 01:08 PM
Brian Patrick
Dec 3, 2015 11:14 PM
RIKIL
May 25, 2012 12:56 AM
austinramsay
Oct 18, 2011 09:28 PM
6CylBill
Oct 18, 2009 12:35 PM
